This slide (page 19) analyzes the efficiency of nonideal boost converter. As you can see from the formula below, the efficiency of boost converter is dependent on duty cycle D and load resistance RL.
The smaller the duty cycle D and load resistance RL, the higher the efficiency.
I would like to understand intuitively how D and RL affect the efficiency. For duty cycle, the smaller duty cycle, the less time that current flows through inductor resistance. So the efficiency will increase.
Is this right?
However, how to explain the similar for load resistance, why smaller load resistance results in higher efficiency?
    \$\begingroup\$ R_L isn't the load resistance, its the series resistance of the inductor (inductor = L). As it grows smaller, the inductor wastes less energy through that resistor so that more can be transferred to the actual load, R. Curious that this "non-ideal" model neglects the voltage drop of the switch, as no real solid state switch has zero voltage drop. \$\endgroup\$ Dec 3, 2016 at 6:46
  • \$\begingroup\$ @LosFrijoles The slide comes from a college class. This is the introduction to losses. Later lessons describe more conduction and switching losses. \$\endgroup\$
    – Adam Haun
    Dec 3, 2016 at 7:11
  • \$\begingroup\$ Ah makes sense. \$\endgroup\$ Dec 3, 2016 at 7:12
  • \$\begingroup\$ Thank you, Los Frijoles. I made mistake in considering RL is load resistance. \$\endgroup\$
    – emnha
    Dec 3, 2016 at 7:54
Current always flows through the inductor resistance. When the switch is in position 1, Vg only supplies power to RL and the inductor. When the switch is in position 2, Vg also supplies power to R. No energy is transferred from source to load in position 1, so position 1 is 0% efficient. Think about what happens with a 0% and a 100% duty cycle.
RL isn't the load resistance, it's the inductor resistance. Decreasing the inductor resistance obviously decreases the conduction losses.
  • \$\begingroup\$ Thanks for the explanation. My silly mistake relating to RL. \$\endgroup\$
    – emnha
    Dec 3, 2016 at 7:53
