I am currently making a theoretical tabletop particle accelerator. and i need the materials in the accelorator to be resonating together at a set frequency (Whcih I can change to test speicific theories) The key is High voltage. --- The secondary requirement is AC current --- The third is the frequency
I can step up household AC via a transformer up to 300KV AC Since transformers are tuned typically at a set frequency I cant change the frequency before I step up the voltage , I have to do it afterwards NOTE: the frequency needs to be changeable so that the different ferromagnetic/parametric and diamagnetic materials i am using have their own fundamental harmonic frequencies and what i am attempting to do is match 2 different materials fundamental frequencies be picking a higher frequency that resonates with both materials used.
Ok with that all explained - How do I change a Ultra High Voltage AC's frequency ...
Other materials lets say one is 15hz and the other is 20hz would resonate both at AC frequency 60hz...
Im testing a lot of materials . One of the most common frequency for a few materials is 85-90 Hz . Some higher frequencies are 300-340hz, lowest would be 10hz
