I'm doing a lab report for a shunt DC motor evaluation. I seem to be stuck on the efficiency vs torque of the motor.
I have plotted a graph of measured \$\frac{P_{out}}{P_{in}}\cdot 100\%\$, which shows that the motor becomes less effcient with more load. (Increments from 0.1Nm to 1.1Nm then stalls.)
This is fine as it shows me that the motor is running aroud 50% efficiency at 0.1Nm and 18% at 1Nm.
My issue is when I try to use some more involved formulas the graph seem to flip around using the recorded values and shows that the motor is most efficient just before stall condition up to 95% so I'm unsure which to use.
The formulas I have been given are
$$ P_{out}= 2\pi T \frac{N}{60} \\P_{in} = V_f I_f + V_a I_a$$
Calculate these then put into the previous formula \$\frac{P_{out}}{P_{in}}\cdot 100\%\$.
Any ideas why the results are flipping?
To add here are my results from the Lab I have calculated the Pin and Pout using Ohms law V.I from the armature values Pin and Field values Pout i have also added the equation 5,6,7 calculations on the right hand side
Here are my calculations using the Eq 5,6,7 from above excell doing the calculations
Hopefully this all makes sense thanks
calculations
  • \$\begingroup\$ Do you have a reference that says to add the armature power to the source power. This is not right. The power in comes only from the source, not the armature. \$\endgroup\$
    – owg60
    Dec 4, 2016 at 12:35
  • \$\begingroup\$ Hi there yes the Pin formula above is what is stated in my lab script. Its a power frame system there is a link to the student manual here which shows the formula. Its under assignement 1 DC shunt motor and evaluation slideshare.net/ScottAnderson114/… \$\endgroup\$
    – jamie8286
    Dec 4, 2016 at 12:53
  • \$\begingroup\$ Im just thinking for my first calculation of effciency which seems to be working I am using armature voltage and current for Pin which they state as V1,I1 and field voltage and current as Pout which is V2,I2. I have tried to swap the values over in my Power formula but it gives high results so im assuming it isnt correct. Thanks \$\endgroup\$
    – jamie8286
    Dec 4, 2016 at 12:58
  • \$\begingroup\$ OK, is your lab on a shunt motors? If it is, do you see increasing current and decreasing speed as you increase the load? If this is shunt, the field current should be constant assuming the power supply voltage is not changing. What units are you measuring N in? \$\endgroup\$
    – owg60
    Dec 4, 2016 at 13:13
  • \$\begingroup\$ Yes it is on shunt motors. Speed recorded in rpm. The speed fluctuated slighty however id say the values are relatively linear througout the range. The torque was increase in increments of .1Nm \$\endgroup\$
    – jamie8286
    Dec 4, 2016 at 14:15
Eq5, Eq6 and Eq7 are correct for a motor with a separately excited field. If the motor has a shunt field, the field and armature voltages would be equal. Since they are not quite equal, the motor is treated like it has a separately excited field.
The Excel spreadsheet must be set up for some other conditions. Since nothing you have posted indicates that anything else is applicable, Eq5, Eq6 and Eq7 should be used.
The RPM increasing with load would seem to indicate that something is going on that is not explained. However I don't see a reason that should have much effect the efficiency very much.
  • \$\begingroup\$ Thanks for your reply Charles the form would not let me add to the original post again. I have edited the results table to show equation 5,6,7 along side as you can see the efficiencies of both sets in excell do not correspond \$\endgroup\$
    – jamie8286
    Dec 4, 2016 at 15:24
  • \$\begingroup\$ The second set must be closer to the actual efficiency. Obviously the efficiency can not be greater than 100%. There must be a problem with the measurements. Is there any possibility that the RPM figures were entered in the reverse order such that the RPM listed for full load is actually belongs at the top of the column, minimum load? \$\endgroup\$
    – user80875
    Dec 4, 2016 at 17:22
  • \$\begingroup\$ Yes I did notice it jumped above 100% it must be must be reading error on that one. No I dont think so we had a table to input them into and recorded each in turn. My main issue at the minute is dont know which to write into the report. Strange the two are so far out? \$\endgroup\$
    – jamie8286
    Dec 4, 2016 at 18:35
\$ V_f I_f\$ is a pure loss, it is needed for the excitation. If the excitation winding would be made of superconductor, then you could fill the current only once and close the windings contacts. The other solution is to use permanent magnets instead.
Then you have a copper loss \$I_a^2 R_a\$ and a iron loss in the rotor \$P_{fe}=k_{fe}\Omega\$, as the rotor field is AC, but let's say that you can omit this for simpler calculation.
Post the formulas you did before, so we can take a look and discuss.
EDIT:
You could rewrite the efficiency formula from loss. \$P_{in}=P_{EM} + P_{loss} = P_{EM}+ P_{Cu}+P_{Fe}\$, where \$P_{EM}\$ is the electromagnetic energy and it is converted into a mechanical energy, so let's make a new formula: $$\eta=\dfrac{P_{mech}}{P_{mech}+P_{loss}}=\dfrac{P_{mech}}{P_{mech}+V_fI_f+I_a^2R_a}$$ The formula is omits the iron losses. At least you won't get over 100% efficiency, additionally you need a resistance of the armature \$R_a\$
What I think is going on here is that you are operating on the lighter than peak efficiency part to the curve. A shunt DC motor has two places where the efficiency goes to zero. One is when speed=0. The other is where torque=0. The maximum efficiency of a DC motor is at higher speeds when lightly loaded. The measurements seem to have some error because you can't be more than 100% efficient. Putting that aside, the way you get what you call inverted is by going from very light loads up to the peak. After the peak you start to go down. At this site; Electric Equipment You'll find this graph;
DC Motor Typical Graph
Notice how starting at very low loads the efficency is going up as you increase the load. Effiency is the green curve.
