I made a simple 0 to 9 up counter using Verilog. The output is 4 LEDs which are turned on when their corresponding bit is 1. The code synthesizes fine, but on the FPGA, only one LED lights on and off repeatedly. The other three LEDs do not light up at all. Here is my code:
module counter(
   input wire clock,
   input wire reset,
   output wire [3:0] o_number
reg [3:0] cur_state;
reg [3:0] next_state;
always @(posedge clock or posedge reset) begin
   if (reset) cur_state <= 4'b0;
   else
    cur_state <= next_state;
end
// Next state function
always @(*) begin
   if (cur_state == 4'b1001) next_state = 4'b0000;
   else next_state = cur_state + 4'b0001;
end
 // Output function
assign o_number = cur_state;
endmodule
module display(
   input wire [3:0] inumber,
   output wire [3:0] LEDs
assign LEDs = inumber;
endmodule
None of the LEDs are broken as they all light up when tested individually. Clock has been adjusted so its period is around 2 seconds.
Please help me out. Thank you.
I revised the counter module. Here are all the files I used:
top.v
module top ( input wire clock, input wire reset, output wire [3:0] LEDs);
counter c1 (.clock(clock), .reset(reset), .o_number(number));
display d1 (.inumber(number), .LEDs(LEDs));
endmodule
counter.v
module counter ( input wire clock, input wire reset, output wire [3:0] o_number);
always @ (posedge clock or posedge reset) begin
    if (reset) cur_state[3:0] <= 4'b0000;
    else begin
        if (cur_state[3:0]==4'b1001) cur_state[3:0] <= 4'b0000;
        else cur_state[3:0] <= cur_state[3:0] + 4'b0001;
    end
end
assign o_number[3:0]=cur_state[3:0];
endmodule
display.v
module display( input wire[3:0] inumber, output wire [3:0] LEDs);
assign LEDs[3:0] = inumber[3:0];
endmodule
top.ucf
NET "LEDs[0]" LOC = K12;
NET "LEDs[1]" LOC = P14;
NET "LEDs[2]" LOC = L12;
NET "LEDs[3]" LOC = N14;
NET "clock" LOC = T9;
NET "reset" LOC = L14;
  • \$\begingroup\$ Wouldn't you want the next state to change on the clock signal rather than * ?? \$\endgroup\$
    – Makoto
    Dec 5, 2016 at 11:22
  • \$\begingroup\$ It is changing at the positive edge of the clock. \$\endgroup\$
    – HelperKing
  • \$\begingroup\$ You change to the next state on clock but you change the state of nextState on * \$\endgroup\$
    – Makoto
    Dec 5, 2016 at 11:24
  • \$\begingroup\$ Would that be a big problem? \$\endgroup\$
    – HelperKing
    Dec 5, 2016 at 11:25
    \$\begingroup\$ There is nothing wrong from a Verilog perspective. My guessing only the LED mapped to LEDs[3] is the only one lighting up. If that is the case, try slowing down your clock to 1/4 its current frequency. If that does not work, double check the mapping in your top.ucf \$\endgroup\$
    – Greg
    Dec 6, 2016 at 4:33
There was a problem with the top module. I did not declare the wire that is used to connect the display and counter module.
Here is the revised top.v:
wire [3:0] number;
endmodule
The LEDs light up correctly according to each state now.
    \$\begingroup\$ There should have been warnings or errors about it. Can you please compile with this declaration and without it and see the difference in compiler/synthesizer messages. \$\endgroup\$
    – Anonymous
    Dec 6, 2016 at 9:34
  • \$\begingroup\$ Actually, there were no warnings or any messages indicating this problem. The documentation says that when no wire is specified in the top module, a one-bit wire is automatically assumed. Hence, I got the result where only one LED was working. \$\endgroup\$
    – HelperKing
    Dec 8, 2016 at 1:51
My guess the issue may be in using cur_state and next_state without indexes. Try
    if (reset) cur_state[3:0] <= 4'b0;
    else begin
        cur_state[3:0] <= next_state[3:0];
end
always @(*) begin
    if (cur_state[3:0] == 4'b1001) next_state[3:0] <= 4'b0000;
    else next_state[3:0] <= cur_state[3:0] + 4'b0001;
end
and
assign o_number[3:0] = cur_state[3:0];
and
Note me adding [3:0] everywhere and changing = to <= in second always construct.
The goal can be achieved by much simpler configuration:
module counter(
input wire clock,
input wire reset,
wire reset_n=~reset;
assign LEDs[3:0] = cur_state[3:0];
always @(posedge clock or negedge reset_n) begin
    if (!reset_n) cur_state[3:0] <= {4{1'b0}};
    else begin
        if (cur_state[3:0] == 4'b1001) cur_state[3:0] <= {4{1'b0}};
        else cur_state[3:0] <= cur_state[3:0] + 4'b1;
    end
end
Update: It did not help - then first thing to do it just to assign LEDs[3:0] with 4'b1111 and see if all LEDs are lit.
Next possible cause of issue is always @(*) begin which is being triggered on change of any input wires for the contents always construct. The only event it happens when you issue reset and cur_state changes to 0, and thus cur_state becomes 4'b0001 and keeps this value.
Update 1: So you have LSB working, other 3 bits not working. You tested that all LEDs are lit when you write 4'b1111 to LEDs's wires. I think code is correct, there's something else being wrong. Consider the following:
  • simplify changing from decimal to hexadecimal. In this case you will only have cur_state[3:0] <= cur_state[3:0] + 4'b1; without any conditions checking for state #10
    always @ (posedge clock or posedge reset) begin if (reset) cur_state[3:0] <= 4'b0000; else cur_state[3:0] <= cur_state[3:0] + 4'b0001; end
  • consider what happens to reset during test. Are you sure it is steady low? Alternatively, remove it from the configuration at all:
    always @ (posedge clock) begin cur_state[3:0] <= cur_state[3:0] + 4'b0001; end
  • synthesize my code above with only one module and reset_n to see if it does not work too.
  • try using other LEDs:
    always @ (posedge clock) begin cur_state[3:1] <= cur_state[3:1] + 3'b001; end
  • \$\begingroup\$ Thanks for your answer, but it didn't solve the problem. I also want to implement it using two modules, so simplification is not needed. I'm using Spartan 3 FPGA board, by the way. \$\endgroup\$
    – HelperKing
    Dec 5, 2016 at 11:08
    \$\begingroup\$ I updated the answer. I think the cause of issue is always @(*). You can keep two modules, but there should be no need to complicate first module with two always constructs. Implementation should be as concise and readable as possible - this is a goal of any programming language including Verilog. \$\endgroup\$
    – Anonymous
  • \$\begingroup\$ I can't quite understand the last paragraph of your answer. Can you please explain it again? \$\endgroup\$
    – HelperKing
    Dec 5, 2016 at 11:27
    \$\begingroup\$ Add your new code to the question (but do not remove old). I can not guess what you tried. Did you prove that all LEDs are working by writing all 1s into output register? My last paragraph says that always @(*) seem to not perform what you want from it. RTFM on what it does and, most importantly, when. \$\endgroup\$
    – Anonymous
    Dec 5, 2016 at 12:37
    \$\begingroup\$ I updated answer with update #1. Your latest code looks ok for me, thus you should exclude statement by statement to see when you start it working as expected. \$\endgroup\$
    – Anonymous
    Dec 5, 2016 at 14:52
