-4
AC/DC symbol I have been trying to find an alt code for the ac/dc symbol, but have not found one or a way to suggest it.
    \$\begingroup\$ What is an alt code? \$\endgroup\$ – PlasmaHH Dec 5 '16 at 15:29
  • \$\begingroup\$ What do you mean by "one or a way to suggest it"? \$\endgroup\$ – winny Dec 5 '16 at 15:30
    \$\begingroup\$ I think OP means a way to type that symbol in unicode. For instance, on linux, press left control, shift and u, then type 2393*space* and "⎓" (DC Symbol) appears or 23e6 and "⏦" (Sine wave) appears. But I cant find the symbol the OP is looking for. source of info: fileformat.info/info/unicode/char/2393/index.htm \$\endgroup\$ – ambitiose_sed_ineptum Dec 5 '16 at 15:45
    \$\begingroup\$ I think they might be referring to Microsoft Windows alt codes, which allow you to enter characters not on the keyboard using the alt key and typing a number. I think the number corresponds to a unicode code point, but I'm not sure. I don't think the symbol they want has a code point. \$\endgroup\$ – Jack B Dec 5 '16 at 15:48
  • \$\begingroup\$ Isn't there an Alt code for an overbar? In which case, you would write ~ + ¯ = ̅~̅ \$\endgroup\$ – Sam Dec 5 '16 at 22:40
I am assuming that by "alt code" you mean Windows/IBM compatible Alt codes for character entry.
Because you did not include a character in your post, it is difficult to say which character you want. I do not believe that exact character exists in Unicode, and consequently you'll need a custom character set and font to use it. I'll list a couple that exist in Unicode that might come in handy, along with the Unicode code point and name:
⎓: U+2393 DIRECT CURRENT SYMBOL FORM TWO
⏦: U+23E6 AC CURRENT
∿: U+223F SINE WAVE
You can type Unicode code points by holding down the Alt key, pressing "+" and entering the hex value of the code point.
Try Unicode 2242.
E.g., in Word, type: \$\small 2242\:alt\:x\$ and you get: ≂
Alternatively use (!):
