My PID controller LOVE 16C-3 has a output of "relay".
Do I connect the output of the PID controller to the inputs of an external SSR?
Or is the relay already built in into the PID controller?
The relay output is SPST rated at 5A:
You cannot use this output to directly control a typical DC-input SSR without an external DC power supply of some type. It's just a normally-open contact.
You should not switch anything like 5A with it either, unless you want it to last a very short time. Typically life at full rated current is only perhaps 100,000 operations, which might be weeks or months 24/7.
They should repeat the datasheet specs within the manual, but I imagine this is just some rebranded no-name Asian product anyway. I doubt Love makes this kind of control these days (they did, many years ago).
It appears from the manual that the output is an SPST relay contact, but the rating of the contact is not stated.
I suggest you contact the manufacturer to cxonfirm the relay contact specifications, and to obtain output wiring recommendations..
The controller data sheet indicates that there are three outputs. A voltage mode output, a current mode output and an on/off relay output via a SPST relay.
  • \$\begingroup\$ The 16C-3 is the relay output version, but I can't make sense of the relay specs - need the contact voltage and currrent ratings. \$\endgroup\$ Dec 5 '16 at 19:19
