I am currently purchasing an off the grid property with two buildings (a house and a shop). This property has a few small solar panels and a small wind generator with some battery storage and separate inverters for each bldg. Instead of purchasing additional solar or wind power capacity (along with storage capacity) I am investigating the purchase of a PTO powered generator to provide the energy I envision needing to operate a future wood shop and potential greenhouse(s). Existing utility service is available but is not close enough to acquire without some additional expense beyond the 100 ft the utility will provide for free. I have an opportunity to purchase either a 25 KW single or a 25 KW 3 phase PTO generator. My understanding is that I can operate (balanced) single phase equipment and systems within a 3 phase service but not necessarily the other way around. My questions are:
1) Is 3 phase power more efficient to generate/use?
2) How difficult or complicated is it going to be to draw a balanced single phase load(s) from a 3 phase service?
3) If I decide to get connected to the utility at some point, will I be able to sell my excess power back to the utility if I am generating 3 phase power?
4) Is there anything else I should be aware of when determining whether to generate single or 3 phase power for my use?
Thank you in advance for any input anybody may provide.
Thanks for the responses. After more research I realize that since I live in the country and there is no 3 phase available from the utility lines that would service my property, I would have to convert any 3 phase power I generated before the utility would allow an inter-tie to my generation. That would require additional expense for a converter and I assume there would be some loss(?) in the conversion?? Anyway, to better understand my questions and concerns (as well as highlighting my electrical ignorance) I would like to expand my story and circumstances.
Here is my scenario. I am purchasing a 2 acre property that has two buildings; a 16'x24' insulated, wired and plumbed single story steel pole bldg (converted dog kennel/house) and a 20'x24' plywood clad, uninsulated, unwired pole shed (workshop). There is no electric service on the property as the original service was provided by a neighboring parcel which was subdivided and sold. The original electrical supply lines were removed and currently the closest transformer is approximately 300' from the closest bldg. There is propane service and wood stoves together with a few small solar panels and a small wind generator hooked up with battery banks and inverters that supply a minimal amount of energy and heating for the bldgs. I have the capability to make biodiesel and clean veg oil and a couple diesel engines that can be used as power plants. I am looking into getting a PTO driven generator to attach to the diesel engine which then can power the workshop and home and potentially a greenhouse in the future. I envision also reclaiming and utilizing waste heat from this setup for space and/or water heating/cooling. Looking forward as I start to layout electrical service and outlets in the workshop and contemplate a separate aquaculture greenhouse in the future, I am trying to determine if my needs would best be served by providing 3 phase or single phase power for the tools and equipment I will be utilizing. I currently do not own any 3 phase equipment but I am aware of the ability to acquire such at considerably reduced cost via auctions and used equipment sales and am cautiously leaning in that direction. My concerns however center around how costly and complicated it is going to be to separate and provide my single phase needs with a 3 phase generator. My cursory understanding is that the loads need to be balanced. As it is my intention to start with a 25kW generator, I am also concerned about not wasting the excess capacity of the generator as my initial needs are considerably less than the 25kW potential maximum. Therefore, I want to investigate if it would be cost effective to pursue a grid intertie and dump my excess capacity to the grid as opposed to just dumping it or before designing an alternative storage/utilization capacity somehow (e.g. batteries, water pumping, alcohol distillation, thermal storage, greenhouse lighting, etc. etc.) I assume that a future aquaculture venture would likely benefit from 3 phase equipment (lighting, pumps, ventilation, etc.)
In desiring self sufficiency and having unutilized waste of any kind as a pet peeve, I guess one of my main questions is; Is 3 phase a more efficient method of utilizing electrical energy and would it be smart to start with 3 phase generation and step down to provide single phase and possibly grid intertie requirements or should I generate single phase and step it up for specific 3 phase applications? Although I have a philosophical commitment to renewable and life-affirming systems thinking I am not independently wealthy (just a poor carpenter) and cost is definitely a factor in this decision-making process. Therefore, I would like to know if installing 3 phase distribution infrastructure (wiring, transfer switch(s), inverters/converters, etc.) would be smarter than installing single phase distribution infrastructure (wiring, transfer switch(s), inverters/converters, etc.)? I know that without specific equipment specs and firm usage applications it is impossible to arrive at precise cost estimates but in generality, which is better and why, 3 phase or single phase? Opinions anyone??
