The build:
I'm building a portable bluetooth boombox. It's a very simple build. The components I'm using are:
  • Bluetooth amplifier board (TDA7492P)
  • 2x50W speakers
  • Rechargeable battery
The amplifier needs to receive 12V. So the battery I will get will be able to deliver this voltage.
My questions:
Now before I buy the battery I have 2 questions that come to my mind.
Will the voltage at the terminals of the Amp be 12V for the entire discharge of the battery or do I need some kind of a voltage regulator?
My other concern is the autonomy of the boombox. I want to be able to combine 2 batteries to double the battery life of the device.
Is there a way I can put together 2x12V batteries and obtain double the autonomy? But keep the voltage to 12V. Do I need to connect them in series or in parallel?
As you can guess i'm new to electronics, and any help would be very much appreciated.
8
Battery discharge curves and you
Batteries indeed vary in voltage as they are discharged. This is a function of the chemistry of the battery, and specified by the battery maker as a discharge curve, characteristic of the chemistry of the battery but also varying with the discharge rate and a few other parameters (such as temperature).
For instance, a 12V sealed-lead-acid battery's discharge curve is shown below (this is one of the most common types of small-ish 12V batteries):
12V SLA manufacturer discharge curve
As you can see, the battery starts off at around 13V and discharges to 9V before not having much life left in it. The good news, though, is that power amplifier ICs like yours don't care much as they are designed to work over a range of voltages; for instance, your TDA7492P can run on anywhere from 8V (a single, rather flat, 12V lead-acid battery) to 26V (almost enough to run on 2 12V lead-acids in series). The volume may go down as the battery drains, but that's OK.
I want more runtime!
You can connect batteries in series to boost the voltage (a 9V alkaline battery is really 6 1.5V alkalines in series, in a neat package), or in parallel to boost the available current capacity without changing the voltage. Since the TDA7492P can't quite take 2 12V lead-acids in series (especially during charging), you'll have to connect your 12V batteries in parallel. (This does introduce complications when you go to charge them, but lead-acid batteries are tolerant of this. Lithium-ions, on the other hand...)
  • \$\begingroup\$ Thanks for these answers both very clear. So you recommend a lead-acid battery rather than lithium-ion for my use? \$\endgroup\$
    – gkpo
    Dec 6, 2016 at 8:55
    \$\begingroup\$ @MonsieurNinja I'm pretty sure this depends on how the charge your batteries and how you transport the whole bluetooth boombox. Lead-acid is chaep and much simpler to charge, but much heavier. For lithium, you don't want to build the charger yourself and you don't want to just tug several batteries/cells to one channel of the charger (unless the battery itself is advertised as too "smart", in which case you see docs on it). \$\endgroup\$ Dec 6, 2016 at 12:11
In English, we say "voltage" rather than "tension".
Depending on the battery type, a fully-charged "12 volt" battery will be somewhat above 12 volts, and the voltage will drop as the battery discharges. The amplifier will probably work fine over a range of power supply voltage. The data sheet for the TDA7492P indicates that it will work down to 8 volts.
You can connect two identical batteries in parallel to double the running time of your amplifier.
    \$\begingroup\$ +1, most audio amplifiers are pretty unspecific on their feed voltage, they have a built-in regulation. \$\endgroup\$
    – Janka
    Dec 6, 2016 at 2:27
