What kind of component is this? Looks like a capacitor but in a white color, measures give high ohm values like 60K
Manual: https://dl.dropboxusercontent.com/u/18602178/Vestel%2B17MB37.pdf
S280
S280
MB
Last picture is from Google, for reference, same model
  • \$\begingroup\$ Yes, can we have a good picture of the mounted part? \$\endgroup\$ Commented Dec 7, 2016 at 3:59
  • \$\begingroup\$ Sure, i will do that. 10m... \$\endgroup\$ Commented Dec 7, 2016 at 4:01
  • \$\begingroup\$ I have added the photos \$\endgroup\$ Commented Dec 7, 2016 at 4:12
    \$\begingroup\$ In context, it seems to be a solder able link or jumper, nothing else. A few are in the pdf. Mostly on power lines. \$\endgroup\$
    – Passerby
    Commented Dec 7, 2016 at 5:10
In the context of the provided schematic, it seems obvious that it is a solder bridge or jumper. The missing S289 and existing S280 shows that this version of the board is using the NOT version of Standby control.
  • \$\begingroup\$ I suspect about that at first view, but after use a multimeter i have no continuity in "S" components and give a high Ohm value. \$\endgroup\$ Commented Dec 7, 2016 at 5:50
  • \$\begingroup\$ I have addded a photo that i grab from google, I'm not sure but in photo looks like it have more components in that place. I'm trying to figure out what components are missing in my board \$\endgroup\$ Commented Dec 7, 2016 at 5:59
    \$\begingroup\$ @TiagoConceição I understand, but the schematic seems to be very clear in this. Look at every other Snnn part. They all act as jumpers or enables. \$\endgroup\$
    – Passerby
    Commented Dec 7, 2016 at 6:21
