I have an application below that requires 2 MCUs to be on a PCB, along with a single FTDI header. Both are programmed thru their RX/TX UART pins.
In normal operation, the RX pin on MCU_1 is connected to TX pin on MCU_2, and vice versa, for inter-MCU communication.
To flash MCU_1, a DP3T switch is toggled to the left to route the MCU_1 TX/RX pins to the FTDI header.
To flash MCU_2, the switch is toggled to the right to route the MCU_2 TX/RX pins to the FTDI header.
So far, I have found DP3T switches with the following configurations: DP3T configurations
I'm looking for such a configuration instead:
ON-X-ON
I'm guessing such a switch probably doesn't exist? How is it best then, using the least wiring/components as possible, to implement such a setup?
  • \$\begingroup\$ Can you guarantee that all the TX outputs will be tristated when the switch is thrown? \$\endgroup\$ Dec 7, 2016 at 23:37
  • \$\begingroup\$ @ThreePhaseEel Hmm the switch should not be thrown during normal operation (i.e. MCU1 <--> MCU2 inter-communication). It serves as some kinda debug switch to allow the user to connect up a FTDI programmer to flash each MCU without having to remove either MCU from the board. \$\endgroup\$
    – loongyh
    Jan 17, 2017 at 20:50
If you can guarantee that all the TX outputs will be tristated (floating) when the switch is thrown, then you can use a 4P3T slide switch wired as follows, for the given switch:
  • 1 and 3 to MCU 1's TX
  • 4 and 7 to MCU 2's TX
  • 5 and 8 to the FTDI's TX
  • 2 to 10
  • 6 to 14
  • 9 and 12 to the FTDI's RX
  • 11 and 16 to MCU 2's RX
  • and 13 and 15 to MCU 1's RX
P.S. the lack of a schematic is due to CircuitLab not having appropriate symbols for a 4P3T switch.
  • \$\begingroup\$ Nice, thanks a bunch! I have made a schematic from the datasheet to visualize this. Straightforward and perfect! \$\endgroup\$
    – loongyh
    Jan 17, 2017 at 20:43
