Good day,
I am using an ULN2003 to control a unipolar stepper motor from my PIC18F45K20. When I only connect the one 12V power cable (Red) the stepper motor works in full step. However, when I connect the other 12V cable the motor stops and has a high pitch noise and the outputs on all the PIC ports go low. So in conclusion when I connect this one specific red cable, nothing works. I tried another stepper motor (same model) the same happens. Any suggestions what it could be?
My motor is similar to this one I found on the web.
Read this: http://digital.ni.com/public.nsf/allkb/B1CC4C64ABBC7D3C86257BC70017B9E2
Your motor may be 4, 6, 8 wire and use of the wires may depend on the way you are configuring your driver (single ended or H-bridge for example). If you are using a ULN2003, it's highly likely you are using this type of connection with one common center connector connected to your supply for the coils:
You need to buzz out the wiring for your stepper motor and understand what wires connect to what coils.
