A component burnt up on my remote control receiver and I want to identify it.
Thank you
closed as off-topic by uint128_t, Ecnerwal, Voltage Spike, Daniel Grillo, dim Dec 8 '16 at 21:23
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – uint128_t, Ecnerwal, Voltage Spike, Daniel Grillo, dim
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Yikes, I think it is time for a new one =-D \$\endgroup\$ – Tyler Dec 8 '16 at 19:25
  • \$\begingroup\$ Thank you. I was trying to just identify the single smd component and replace it with one off of a salvaged board. I know the entire receiver is cheap but my location and timeframe has lead me searching for a solution other than buying a entire new one then waiting for it ect. I like to do things the hard way I guess. Thank you for your email information and the speedy reply. \$\endgroup\$ – opal stivers Dec 8 '16 at 19:54
  • \$\begingroup\$ The problem is that there's about half a million different parts in the SOT23-6 package, everything from regulators to ADCs to micros to radios to good ol' transistors, so unless there's someone here with the same unit who can do a cross reference on the id No. (those things are too small for real part numbers) and has a rough idea what it's supposed to do, then I'm afraid you're probably out of luck. \$\endgroup\$ – Sam Dec 8 '16 at 21:53
This board is in pretty bad shape. There are two obvious failures, and these tend to ripple downstream and cause other problems:
It looks to me that these are for power regulation. The corroded part may be the same as the orange tantalum capacitor next to it. If so, they could be input and output caps to a voltage regulator. And the 6-pin (destoyed) IC could be that regulator.
I think it's time to replace it!
