... Or should I leave them not connected if I'm not going to trim them?
I think I fried an LM741 when it's output was only connected to a single MOSFET's gate (and the single supply was <12V). The only thing I can figure is it's bad to ground those offset null pins, but I can't tell from its datasheet.
  • \$\begingroup\$ Why use the 741? It's obsolete. \$\endgroup\$ Commented Dec 10, 2016 at 9:02
  • \$\begingroup\$ @LeonHeller The usual reason: because it's on hand \$\endgroup\$ Commented Dec 10, 2016 at 9:37
    \$\begingroup\$ what does the data sheet say? \$\endgroup\$
    – Neil_UK
    Commented Dec 10, 2016 at 12:18
    \$\begingroup\$ @Neil_UK It says nothing about the offset pins under "Absolute Maximum Ratings", although under "Electrical Characteristics" it does give a typical and maximum current for those pins. So does that mean grounding those pins is bad because it'll exceed its "Electrical Characteristics", or that it's okay because nothing is said under "Maximum Ratings"? I can't tell from its datasheet \$\endgroup\$ Commented Dec 10, 2016 at 14:01
This is what a 741 looks like internally: -
Bottom left are the trim pins and, as can be seen, they connect to the -Ve rail of the op-amp via 1 kohm resistors so don't mess with them, leave them open circuit if not being used or you will upset the balance of the current sources feeding the input transistor emitters.
Normally, the trim pins are used like this: -
As you can see, their recommended connection adds resistance in parallel with the two 1 kohm resistors shown in the top picture. Taking one or both to ground (normally regarded as mid-rail) will bias off those current sources.
