Consider the transfer function of a block being $$\frac{1}{s-0.5}$$ which is unstable in open loop. If we go for a feedback, magically it becomes stable even with the presence of the inherently unstable block. My thoughts on these are
- When an element is unstable , it doesn't mean it is unstable for all inputs. For certain inputs the block can still produce stable outputs.
- During feedback, the input given to the the block gets modified such that output doesn't blow up.
My questions are
- Are the above observations correct?
- The impulse response of the block is $$ e^{0.5t}u(t) $$ What the block does is, take the area under the signal at present instant and blow it up for subsequent instants. If so, a positive valued input should blowup the output exponentially. Then why is the output not blown up (exponentially) in following case, shown in figure?
The signal shown as input is the actual error signal when we use the block in a closed loop format with unit step input.
