I have built a peak detector circuit using op-amps/comparators to amplify the signal from an electret microphone, hold the peak signal and create a sharp logic edge when a peak is detected to be sent to a microcontroller.
I have built the circuit as follows setting up OA1 as a non inverting amplifier with a gain of 1000, but the voltage out from the OA1 remains fixed at about 4.5V no matter how much noise I make into the microphone. The comparator part of the circuit is outputting approximately 2V low and 5V high depending on how I set the potentiometer. All the components appear to be working.
