I'm trying to use the nrf24l01 transceiver on altera board de2-115. I would like to send a signal from the altera board using this spi module to another spi module and use the spi module on the receiving side to turn on an LED and a vibrating motor. Does anyone know if this board works with this spi module and how ?
  • \$\begingroup\$ Exactly the same comment as to this question of 27min ago (are you two on the same lab/course/assignment?): Sorry, this is a little too broad. Could you come up with a sketch of any design that you might want to discuss? \$\endgroup\$ Commented Dec 11, 2016 at 14:00
  • \$\begingroup\$ Plus, you did not even ask a question! \$\endgroup\$ Commented Dec 11, 2016 at 14:01
  • \$\begingroup\$ I want to know if the spi module is applicable with the altera board and no we are not. My project is completely different \$\endgroup\$
    – Lose' CKi
    Commented Dec 11, 2016 at 14:35
    \$\begingroup\$ That's actually question, and you should edit your question to include that! But, after your research you know that both the nrf chip and the FPGA "speak" SPI; you probably already know how SPI works and are perfectly capable of searching for SPI examples for that FPGA – I wonder whether you can specify that question "will it work?" further to say why you think it might not work.You've got a legitimate question,but,you don't sound like the type that needs to verify every single design step with someone else, why do you do that here? \$\endgroup\$ Commented Dec 11, 2016 at 14:41
  • \$\begingroup\$ I don't have experience with this board, it's the first time I work on it and I looked for the way to send signals from it through the spi transceiver but I couldn't find anything online for it so I figured I should ask here if someone knows if this is going to work and how can I do it ? \$\endgroup\$
    – Lose' CKi
    Commented Dec 11, 2016 at 14:46
The DE2-115 FPGA board does not have any hardware dedicated to SPI (actually, it does for loading its configuration from flash, but not for other uses), so the SPI logic must be synthesized using the FPGA fabric.
There are a few different options as to how the SPI logic will interface with other system components. In the end, all choices end up using GPIO for output. One would select four pins to use (clk, mosi, miso, and cs) and assign your module's ports to those pins.
But, there are a few different choices you have for how to interface your controlling logic with the SPI core:
  1. Use a "normal" verilog module
  2. Use a SPI component (Altera provides one for their Avalon bus architecture)
  3. Instantiate a CPU (such as NIOS) and use bit-banging to construct the SPI signals using a 4-bit "conduit".
If you're using an Avalon bus already, I'd suggest that method #2 would be the simplest. But, if you are not using SoC design techniques, you may want to investigate writing (or buying or downloading) a pre-written SPI-interface module.
