I'm building a bookcase, to which I'd like to add lighting controlled by an Arduino or Raspberry Pi. I've gotten most of the software bits figured out, but I'm not sure I've gotten the power part figured out as well as I need to. I'm using Adafruit's NeoPixel LED strip for the lighting.
Each shelf is be 31 inches wide, there will be 8 shelves total in the bookshelf. I can't connect all the shelves in series, because the product documentation tells me each "strip" of LEDs can be no more than 5m long, so I'm planning on having each pair of shelves as one "strip", for a total of four strips in parallel. By my rough calculations, I'll end up with ~ 96 LEDs per series (48 per shelf times two shelves per series), requiring almost 6A of maximum current draw per series.
First, am I at least in the right ballpark with these power requirements, or am I so far off as to need professional electrical help?
Second, if these numbers are correct, should I try to find a single 24A 20VDC power supply, or should I instead use four (4) 6A 5VDC supplies? What are the main drivers for choosing one over another?
