I've been trying to design a module that will allow me to modify selected slave responses on an I2C bus. Here is the original bus configuration (the pull-ups and power connections are not shown for clarity:
There's only 2 devices on this bus and it's only 100kHz. A controller MCU (I2C master) and the RFID card reader (I2C slave) NXP PN512. I can't modify the controller firmware or change the I2C bus transactions. The good part is that the Controller sends only 2 types of transactions:
Master (Write Register) - <s><address+W><register number><data><p>
Master (Read Register) - <s><address+W><register number><p><s><address+R><data><p>
What I want to do is to replace selected data bytes during the Master register read with my own bytes. I can send the register numbers the MCU wants to read to my PC over UART (921.6kbaud). I can process them in C/C++ or Python there. When I receive the register number whose value needs to be replaced I can send a fake byte back to my device and it will take care of sending it back to the controller replacing the original card response.
At first I split the I2C bus into two buses:
I tried Arduino Nano and later a CPLD using clock stretching. ATmega328 hardware I2C facing the MCU controller could not keep up as sometimes the start sequence was generated sooner than 5us after previous stop cycle. So every now and then the AVR was NAK'ing a read transaction. The CPLD could handle the stop/start speed it turned out the bus stretching was disabled in the MCU.
I came up with an idea that I can "predict" Master register read by detecting a single byte write since I'm sure that it's followed by a read. It seems that I had enough time during the following read cycle address write to bring in the byte from the slave. That did not quite work. The bus transactions seemed fine at the beginning (approx. first 5 seconds) but then the controller was ceasing all communications on the bus as if it detected that it's not directly talking to tag read.
The card reader can also generate interrupts to the master. The IRQs are a timer or event based. I attributed the problem to the delay I was inherently introducing on the bus. I might have been wrong but I came up with another "zero-delay" design.
The idea is that I can only break the SDA line and leave the SCL line connected between the master and the slave. This way I can still replace bytes on the data line in either direction. The design proved to be more complicated as I have to control the SDA line direction based on the bus cycle. Here is the VHDL code that handles the bus transactions and sends hex bytes over UART to the computer. Receiving bytes from the computer is not yet implemented:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity I2C_Sniffer is
port (
clk : in std_logic;
scl_master : in std_logic;
sda_master : inout std_logic;
sda_slave : inout std_logic;
tx : out std_logic
end entity I2C_Sniffer;
architecture arch of I2C_Sniffer is
signal clkDiv: std_logic_vector(7 downto 0) := (others => '0');
type I2C_STATE is (I2C_IDLE, I2C_MASTER_WRITE, I2C_SLAVE_ACK, I2C_MASTER_READ, I2C_MASTER_ACK);
signal i2cState: I2C_STATE := I2C_IDLE;
type I2C_BUS_DIR is (MASTER_TO_SLAVE, SLAVE_TO_MASTER);
signal i2cBusDir: I2C_BUS_DIR := MASTER_TO_SLAVE;
signal i2cRxData: std_logic_vector(7 downto 0);
signal i2cCntr: integer range 0 to 8 := 0;
signal i2cAddr: std_logic := '1';
signal i2cCmd: std_logic := '0';
signal scl_d: std_logic := '1';
signal scl: std_logic := '1';
signal sda_d: std_logic := '1';
signal sda: std_logic := '1';
--Strobes for SCL edges and Start/Stop bits
signal start_strobe : std_logic := '0';
signal stop_strobe : std_logic := '0';
signal scl_rising_strobe : std_logic := '0';
signal scl_falling_strobe : std_logic := '0';
type UART_STATE is (UART_IDLE, UART_START, UART_DATA, UART_STOP);
signal uartState: UART_STATE := UART_IDLE;
signal uartTxRdy: std_logic := '0';
signal uartTxData: std_logic_vector(7 downto 0);
signal uartCntr: integer range 0 to 8 := 0;
begin
CLK_DIV: process (clk)
begin
if rising_edge(clk) then
clkDiv <= std_logic_vector(unsigned(clkDiv) + 1);
end if;
end process;
I2C_STROBES: process (clk)
begin
--Pipelined SDA and SCL signals
scl_d <= scl_master;
scl <= scl_d;
scl_rising_strobe <= '0';
if scl = '0' and scl_d = '1' then
scl_rising_strobe <= '1';
end if;
scl_falling_strobe <= '0';
if scl = '1' and scl_d = '0' then
scl_falling_strobe <= '1';
end if;
if i2cBusDir = MASTER_TO_SLAVE then
sda_d <= sda_master;
sda <= sda_d;
else
sda_d <= sda_slave;
sda <= sda_d;
end if;
start_strobe <= '0';
if sda_d = '0' and sda = '1' and scl = '1' and scl_d = '1' then
start_strobe <= '1';
end if;
stop_strobe <= '0';
if sda_d = '1' and sda = '0' and scl = '1' and scl_d = '1' then
stop_strobe <= '1';
end if;
end if;
end process;
BUS_DIR: process(sda_master, sda_slave, i2cBusDir)
begin
sda_slave <= sda_master;
sda_master <= 'Z';
else
sda_master <= sda_slave;
sda_slave <= 'Z';
end if;
end process;
I2C: process(clk)
begin
uartTxRdy <= '0';
case i2cState is
when I2C_IDLE =>
i2cBusDir <= MASTER_TO_SLAVE;
if start_strobe = '1' then
i2cAddr <= '1';
i2cCntr <= 0;
i2cState <= I2C_MASTER_WRITE;
end if;
-- Master Write (Address/Data)
when I2C_MASTER_WRITE =>
if stop_strobe = '1' then
i2cState <= I2C_IDLE;
uartTxData <= "00001010";
uartTxRdy <= '1';
end if;
if scl_rising_strobe = '1' then
if i2cCntr <= 7 then
i2cRxData(7 - i2cCntr) <= sda;
i2cCntr <= i2cCntr + 1;
end if;
end if;
if i2cCntr = 4 then
case i2cRxData(7 downto 4) is
when "0000" => uartTxData <= "00110000"; --0
when "0001" => uartTxData <= "00110001"; --1
when "0010" => uartTxData <= "00110010"; --2
when "0011" => uartTxData <= "00110011"; --3
when "0100" => uartTxData <= "00110100"; --4
when "0101" => uartTxData <= "00110101"; --5
when "0110" => uartTxData <= "00110110"; --6
when "0111" => uartTxData <= "00110111"; --7
when "1000" => uartTxData <= "00111000"; --8
when "1001" => uartTxData <= "00111001"; --9
when "1010" => uartTxData <= "01000001"; --A
when "1011" => uartTxData <= "01000010"; --B
when "1100" => uartTxData <= "01000011"; --C
when "1101" => uartTxData <= "01000100"; --D
when "1110" => uartTxData <= "01000101"; --E
when "1111" => uartTxData <= "01000110"; --F
when others => uartTxData <= "00111111"; --?
end case;
uartTxRdy <= '1';
end if;
if i2cCntr = 8 then
case i2cRxData(3 downto 0) is
end case;
uartTxRdy <= '1';
end if;
if i2cCntr = 8 then
if scl_falling_strobe = '1' then
i2cState <= I2C_SLAVE_ACK;
if i2cAddr = '1' then
i2cCmd <= i2cRxData(0);
i2cAddr <= '0';
end if;
end if;
end if;
when I2C_SLAVE_ACK =>
i2cBusDir <= SLAVE_TO_MASTER;
i2cCntr <= 0;
if i2cCmd = '0' then
else
i2cState <= I2C_MASTER_READ;
end if;
end if;
when I2C_MASTER_READ =>
uartTxRdy <= '1';
end if;
end if;
end if;
if i2cCntr = 4 then
end case;
uartTxRdy <= '1';
end if;
if i2cCntr = 8 then
end case;
uartTxRdy <= '1';
end if;
if i2cCntr = 8 and scl_falling_strobe = '1' then
i2cState <= I2C_MASTER_ACK;
end if;
when I2C_MASTER_ACK =>
i2cCntr <= 0;
end if;
uartTxData <= "00001010"; -- \n
uartTxRdy <= '1';
end if;
end case;
end if;
end process;
UART: process (clk, clkDiv(1), uartTxRdy)
begin
case uartState is
when UART_IDLE =>
if uartTxRdy = '1' then
uartState <= UART_START;
end if;
when UART_START =>
if clkDiv(1 downto 0) = "00" then
tx <= '0';
uartState <= UART_DATA;
uartCntr <= 0;
end if;
when UART_DATA =>
if uartCntr <= 7 then
uartCntr <= uartCntr + 1;
tx <= uartTxData(uartCntr);
else
tx <= '1';
uartState <= UART_STOP;
end if;
end if;
when UART_STOP =>
tx <= '1';
uartState <= UART_IDLE;
end if;
end case;
end if;
end process;
end architecture arch;
Below are the bus transations captured with the CPLD controlling the SDA line.
Register write:
Register read:
You can see a few glitches when the bus direction changes. That's caused by the differences in timing between the CPLD changing the bus direction and the card reader generating an ACK. The ACK level seems to be stable on the rising edge of the SCL. As far as I know that's all you need.
With this thing in place the controller behaves the same way as with the split buses suspending any bus activity within a few seconds. I also test that w Arduino that mocks that MCU and generates bus traffic for me and it looks like Arduino also freezes every now and then. So I guess I may have some kind of issue with the VHDL state machine where under some conditions I get stuck in one state with no way out. Any ideas?
There's only 2 devices on this bus running at 100kHz
and thenThe hardware I2C was a slave and a bit banged I2C was a master on the card reader bus at 1Mbps
. Why are there two buses? Why the need for the high speed bus? Provide a sketch of your initial design and try to clarify your question. \$\endgroup\$
