I have some brushed motors near to a 433 MHz RF receiver. They're controlled by a 490 Hz PWM signal. The electrical noise they produce is not a problem for the circuit, but it is for the receiver.
How can I reduce the noise, at least on the frequencies interfering with the transmitter?
I read that putting a ceramic capacitor across the motor's terminals and one from each terminal to the motor's case would help; if it's true, what size should they be? I unfortunately don't have technical information about the motors. I'm quite sure they're the same as those, but there isn't much data on that site...
