I've done a basic test sending a single int
value to Arduino from Processing via the Processing Serial library and all's fine. I would like to send multiple int values, but not entirely sure what's the best way to that.
Acoording to the docs Serial.write
writes bytes, chars, ints, bytes[], Strings to the serial port
so one option would be to send a string I can split and get the values:
arduino.write(intValue1+","+intValue2);
but I'm not sure how I would read the data convert when I receive it in Arduino.
Another thing that comes into mind is to use a byte[]
since I'm sending multiple values, but I haven't worked with bytes much, so any advice on how pack/unpack two into a byte[]
and back would be really handy.
Thanks!
