My prelit tree has strings of LED lights and each bulb has three wires going to it. Looking on the web there are a number of sites that describe how to repair strings wired in series that have two wires per bulb. However I cannot find any reference to strings with three wires per bulb.
  • \$\begingroup\$ Dimmable lights? We need images or a bit more info to answer this... \$\endgroup\$ – 12Lappie Dec 16 '16 at 16:07
  • \$\begingroup\$ There should be a site for how do I search with intelligent keywords google.ca/… \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Dec 18 '16 at 3:04
I took a string apart and traced the circuit. It's interesting- pairs of LED's are in parallel and these pairs are wired in series. The string uses a full-wave rectifier (improves flicker) and splits the diodes between the plug end and receptacle end (so both plug and receptacle are not too large). So for an extra wire per bulb this design gains redundancy- one bulb of any or multiple pairs can be missing or open and the string still lights. However if both bulbs of a pair are missing or open the string is dark.
Of course a parallel string is better for reliability but I think that would require four wires per bulb and a brick power supply of some type.
So as far as repairing it seems best to replace burned out bulbs immediately. This is because if the other bulb paired with a burned out bulb goes then the entire string goes. Then tracing which bulb is bad requires special effort. Of course I've read that sometimes LED bulbs fail shorted instead of open. So this helps.
Here is a schematic:
Typically one of the wires would be parts of the series string and the other two would be connected to each side of the power. That allows sets of series strings to be daisy-chained. Below diagram from here:
