I use STM32F407G-DISC1 board. I have run some examples with VCP based on STD library. Everything is OK. Then I have tried to generate code by CubeMX. And something interesting happens.
If not to add any code, then VCP is defined by host and Terminal can connect that.
If I add CDC_Transmit_FS in endless loop of main(), it works
volatile uint32_t time_var = 3e7;
while (1)
    while(time_var) {
    time_var--;
CDC_Transmit_FS(b, 4);
time_var = 3e8;
If instead of internal while loop I use HAL_Delay function, then terminal can't open the port.
while (1) {
Hal_Delay(5e3);
So, COM port is defined in DeviceManager, but terminal can't connect that. It happens even before the first call of CDC_Transmit_FS, though hUsbDeviceFS is already initialized.
  • \$\begingroup\$ CDC_Transmit_FS() never gets called in your second example. Look at the following part while(1) Hal_Delay(5e3); more closely. \$\endgroup\$
    – Turbo J
    Dec 16, 2016 at 19:38
  • \$\begingroup\$ Sorry, of course there is "{" after while. \$\endgroup\$ Dec 16, 2016 at 20:42
This is probably because your Hal_Delay function is not working properly. Hal_Delay function will enter a busy loop that will compare an interrupt incremented value with the value you specify as argument. The interrupt functions will get initiated when calling HAL_init(), otherwise you need to make this configuration yourself.
To summarize, make sure that the HAL_Tick function is getting called before using HAL_Delay.
