First, I will present a method that uses Mathematica to solve this problem. When I was studying this stuff I used the method all the time (without using Mathematica of course).
Well, we are trying to analyze the following opamp-circuit:
When we use and apply KCL, we can write the following set of equations:
\begin{cases}
\text{I}_1=\text{I}_2+\text{I}_3+\text{I}_4\\
0=\text{I}_3+\text{I}_4+\text{I}_5
\end{cases}\tag1
When we use and apply Ohm's law, we can write the following set of equations:
\begin{cases}
\text{I}_1=\frac{\text{V}_\text{i}-\text{V}_1}{\text{R}_1}\\
\text{I}_2=\frac{\text{V}_1}{\text{R}_2}\\
\text{I}_3=\frac{\text{V}_1-\text{V}_3}{\text{R}_3}\\
\text{I}_4=\frac{\text{V}_1-\text{V}_2}{\text{R}_4}\\
\text{I}_4=\frac{\text{V}_2-\text{V}_3}{\text{R}_5}
\end{cases}\tag2
Now, we can put equations \$(1)\$ into \$(2)\$ to get:
\begin{cases}
\frac{\text{V}_\text{i}-\text{V}_1}{\text{R}_1}=\frac{\text{V}_1}{\text{R}_2}+\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{\text{V}_1-\text{V}_2}{\text{R}_4}\\
0=\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{\text{V}_1-\text{V}_2}{\text{R}_4}+\text{I}_5\\
\frac{\text{V}_\text{i}-\text{V}_1}{\text{R}_1}=\frac{\text{V}_1}{\text{R}_2}+\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{\text{V}_2-\text{V}_3}{\text{R}_5}\\
0=\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{\text{V}_2-\text{V}_3}{\text{R}_5}+\text{I}_5
\end{cases}\tag3
Now, using an ideal opamp, we know that:
$$\text{V}_+=\text{V}_-=\text{V}_2=0\space\text{V}\tag4$$
So, we can rewrite \$(3)\$ as follows:
\begin{cases}
\frac{\text{V}_\text{i}-\text{V}_1}{\text{R}_1}=\frac{\text{V}_1}{\text{R}_2}+\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{\text{V}_1-0}{\text{R}_4}\\
0=\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{\text{V}_1-0}{\text{R}_4}+\text{I}_5\\
\frac{\text{V}_\text{i}-\text{V}_1}{\text{R}_1}=\frac{\text{V}_1}{\text{R}_2}+\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{0-\text{V}_3}{\text{R}_5}\\
0=\frac{\text{V}_1-\text{V}_3}{\text{R}_3}+\frac{0-\text{V}_3}{\text{R}_5}+\text{I}_5
\end{cases}\tag5
Hence, we can solve for the transfer function:
$$\mathcal{H}:=\frac{\text{V}_3}{\text{V}_\text{i}}=-\frac{\text{R}_2\text{R}_3\text{R}_5}{\text{R}_1\text{R}_2\left(\text{R}_3+\text{R}_4+\text{R}_5\right)+\text{R}_3\text{R}_4\left(\text{R}_1+\text{R}_2\right)}\tag6$$
Where I used the following Mathematica-code:
In[1]:=Clear["Global`*"];
V2 = 0;
FullSimplify[
Solve[{I1 == I2 + I3 + I4, 0 == I3 + I4 + I5, I1 == (Vi - V1)/R1,
I2 == V1/R2, I3 == (V1 - V3)/R3, I4 == (V1 - V2)/R4,
I4 == (V2 - V3)/R5}, {I1, I2, I3, I4, I5, V1, V3}]]
Out[1]={{I1 -> ((R3 R4 + R2 (R3 + R4 + R5)) Vi)/(
R1 R3 R4 + R2 R3 R4 + R1 R2 (R3 + R4 + R5)),
I2 -> (R3 R4 Vi)/(R1 R3 R4 + R2 R3 R4 + R1 R2 (R3 + R4 + R5)),
I3 -> (R2 (R4 + R5) Vi)/(
I4 -> (R2 R3 Vi)/(R1 R3 R4 + R2 R3 R4 + R1 R2 (R3 + R4 + R5)),
I5 -> -((R2 (R3 + R4 + R5) Vi)/(
R1 R3 R4 + R2 R3 R4 + R1 R2 (R3 + R4 + R5))),
V1 -> (R2 R3 R4 Vi)/(R1 R3 R4 + R2 R3 R4 + R1 R2 (R3 + R4 + R5)),
V3 -> -((R2 R3 R5 Vi)/(
R1 R3 R4 + R2 R3 R4 + R1 R2 (R3 + R4 + R5)))}}
My equation was also confirmed using LTspice.
When we want to apply the derivation from above to your circuit we need to use Laplace transform (I will use lower case function names for the functions that are in the (complex) s-domain, so \$\text{y}\left(\text{s}\right)\$ is the Laplace transform of the function \$\text{Y}\left(t\right)\$):
- $$\text{R}_2=\frac{1}{\text{sC}_1}\tag7$$`
- $$\text{R}_5=\frac{1}{\text{sC}_2}\tag8$$
So, we can rewrite the transfer function as:
$$\mathscr{H}\left(\text{s}\right)=-\frac{\frac{1}{\text{sC}_1}\cdot\text{R}_3\cdot\frac{1}{\text{sC}_2}}{\text{R}_1\cdot\frac{1}{\text{sC}_1}\cdot\left(\text{R}_3+\text{R}_4+\frac{1}{\text{sC}_2}\right)+\text{R}_3\text{R}_4\left(\text{R}_1+\frac{1}{\text{sC}_1}\right)}=$$
$$-\frac{\text{R}_3}{\text{C}_1\text{C}_2\text{R}_1\text{R}_3\text{R}_4\text{s}^2+\text{C}_2\left(\text{R}_3\text{R}_4+\text{R}_1\left(\text{R}_3+\text{R}_4\right)\right)\text{s}+\text{R}_1}\tag9$$
Now, when working with sinusoidal signals we can use \$\text{s}:=\text{j}\omega\$ (where \$\text{j}^2=-1\$ and \$\omega=2\pi\text{f}\$ with \$\text{f}\$ is the frequency of the input signal in Hertz). So, we get:
$$\underline{\mathscr{H}}\left(\text{j}\omega\right)=-\frac{\text{R}_3}{\text{C}_1\text{C}_2\text{R}_1\text{R}_3\text{R}_4\left(\text{j}\omega\right)^2+\text{C}_2\left(\text{R}_3\text{R}_4+\text{R}_1\left(\text{R}_3+\text{R}_4\right)\right)\text{j}\omega+\text{R}_1}=$$
$$-\frac{\text{R}_3}{\text{R}_1-\text{C}_1\text{C}_2\text{R}_1\text{R}_3\text{R}_4\omega^2+\text{C}_2\left(\text{R}_3\text{R}_4+\text{R}_1\left(\text{R}_3+\text{R}_4\right)\right)\omega\text{j}}\tag{10}$$
So, the absolute value if given by:
$$\left|\underline{\mathscr{H}}\left(\text{j}\omega\right)\right|=\frac{\text{R}_3}{\sqrt{\left(\text{R}_1-\text{C}_1\text{C}_2\text{R}_1\text{R}_3\text{R}_4\omega^2\right)^2+\left(\text{C}_2\left(\text{R}_3\text{R}_4+\text{R}_1\left(\text{R}_3+\text{R}_4\right)\right)\omega\right)^2}}\tag{11}$$
Now, it is relatively hard to find the cut-off frequency for the transfer function in \$(11)\$. In order to make it a bit easier we assume a few things:
- $$\text{R}_1=\text{R}_3=\text{R}_4=\text{R}\tag{12}$$
- $$\text{C}_1=\text{C}_2=\text{C}\tag{13}$$
So, the absolute value becomes:
$$\left|\underline{\mathscr{H}}\left(\text{j}\omega\right)\right|=\frac{1}{\sqrt{1+\left(\text{CR}\omega\right)^2\left(7+\left(\text{CR}\omega\right)^2\right)}}\tag{14}$$
Now, we can find the cut-off frequency (\$\omega_0\$) by finding:
$$\left|\underline{\mathscr{H}}\left(\text{j}\omega_0\right)\right|=\frac{1}{\sqrt{2}}\cdot\hat{\left|\underline{\mathscr{H}}\left(\text{j}\omega\right)\right|}\space\Longrightarrow\space\omega_0=\sqrt{\frac{\sqrt{53}-7}{2}}\cdot\frac{1}{\text{CR}}\tag{15}$$
So, in your case we want to have \$\text{f}_0=1500\space\text{Hz}\$ which implies \$\omega_0=3000\pi\space\text{rad/sec}\$ we get:
$$3000\pi=\sqrt{\frac{\sqrt{53}-7}{2}}\cdot\frac{1}{\text{CR}}\space\Longleftrightarrow\space$$
$$\text{CR}=\sqrt{\frac{\sqrt{53}-7}{2}}\cdot\frac{1}{3000\pi}\approx0.000039708\space\text{sec}\tag{16}$$
So, the absolute value will be:
$$\left|\underline{\mathscr{H}}\left(\text{j}\omega\right)\right|=\frac{1}{\sqrt{1+\left(\sqrt{\frac{\sqrt{53}-7}{2}}\cdot\frac{1}{3000\pi}\cdot\omega\right)^2\left(7+\left(\sqrt{\frac{\sqrt{53}-7}{2}}\cdot\frac{1}{3000\pi}\cdot\omega\right)^2\right)}}\tag{17}$$
