I am new in proteus and I have done a pcb design.I have the following doubts in pcb design using proteus.
  1. I need to connect a 100W bulb through the relays. Now the trace style is T30 .Is it sufficient for AC transmission to power a 100W bulb?
  2. I don't know how to get the dimension of the pcb I have done. I would like to
    know how to get the length and width of the pcb...? what is the dimension of a single tile in the grid...?
this is my pcb design
There's a mode called Dimension Mode. You can access this mode by clicking the button with a diagonal two-headed arrow symbol from the toolbar on the left:
At this mode, if you draw a line, it will show the length:
If you want to see the length in metric unit instead of imperial unit, go to View menu then click "Metric". All the dimensions will show in milimeters.
  • \$\begingroup\$ thank u..can you please tell something about first question \$\endgroup\$ – iqbalpalemad Dec 19 '16 at 7:28
  • \$\begingroup\$ Assuming the supply voltage for the bulb is 230Vac, so steady state load current will be 100/230=~450mA. Go to this page. Enter 0.45 for Current, 1 for Thickness, 10 for Temp. Rise and 25 for Amb. Temp. For trace length, if you click a trace on Ares, you'll see its length on the status bar at the bottom like "Tagget Route [ ... Length - 0.65in ]" and enter this value for "Trace Length" on the calculator page. You'll see the required trace width under "Results for External Layers in Air:" section. \$\endgroup\$ – Rohat Kılıç Dec 19 '16 at 7:49
  • \$\begingroup\$ i have done this which shows .128mm but how to apply this in proteus there the trace style is shown like T20 T30 \$\endgroup\$ – iqbalpalemad Dec 19 '16 at 9:49
  • \$\begingroup\$ @iqbalpalemad There's a button named "C" (Create) on top-left of the TRACES list (the list where T30, T20 etc. is placed in). Click that button, "Edit Trace Style" window will appear. Type a name like "M.128mm" or whatever you want and type ".128mm" into the Width textbox then click "OK". You'll have a style with a trace width of 0.128mm. Select this new style from the list then redraw the corresponding trace. \$\endgroup\$ – Rohat Kılıç Dec 19 '16 at 10:26
  • \$\begingroup\$ @iqbalpalemad Also please note that the calculated trace width is the "minimum" required value. I personally recommend you to use a larger value (e.g. 0.35mm instead of 0.128mm). \$\endgroup\$ – Rohat Kılıç Dec 19 '16 at 10:57
