The Setup:
I am currently prototyping a wheatstone bridge setup to measure small resistance changes. I don't have the sensor I'll be using yet, so I've simulated it using trim pots. I am using a SAML21 xplained board. I have side A and B of the wheatstone's bridge connected to two of the SAM's internal OPAMPS with programmable gain. I then feed the OPAMP outputs into the 12 bit ADC in signed differential mode.
The Problem:
I have tried a few different configurations and I can't seem to make heads or tails of it. A bridge voltage of 2mV(or and imbalance of 100 ohms between R2 and Rx if you prefer) is created from a 1V source voltage. When referenced to ground as the OPAMPs do when it is passed through them, this is actually about 580mV for side A and 578mV for side B. The gain is set to 3, so when passed to the positive and negative ADC inputs it comes out to about 2.32V for the positive terminal and 2.31V for the negative.
What I get out is about -1000 ADC counts. This makes no sense to me. The positive end is set up to the node of higher potential. So I tried changing the reference voltage. It was set up to an internal 1V ref and I changed it to one labeled INTVCC0 with the comment "1/1.48VCC reference". The result then came out to 203 counts. Finally I tried another reference INTVCC1 commented "1/2VCC (only for internal VCC > 2.1V)". This resulted in about 700 counts.
To my understanding of the differential measurement, the reference voltage should not affect it since the difference between the two is all that matters.
I have tried changing the bridge voltage by a decent factor on all these references and the changes I see make no sense.
The Question(s):
Basically I am a bit lost as to what the ADC is telling me, and what changes I can make to get the desired measurement. I understand single ended well enough and what the reference voltage does there, but I cant seem to manage this transfer to differential. Can anyone point out problems or things to check?
Side question, could I take the line I'm using for the negative input and instead connect it to an external reference pin for the ADC and use the other input as the positive pin in the single ended input mode? If so, how is that different from what I'm currently doing?
