-1
Does an instruction like this: MOV P1.0, #1 makes the port P1 bit 0 High so i can drive an LED for example, or it just makes it FLOAT so i can use an external circuitry to light the LED. If so, does this mean that we can't output a "real" HIGH to the ports?
    \$\begingroup\$ Surely this is answered in the datasheet! \$\endgroup\$ – Olin Lathrop Dec 20 '16 at 12:08
  • \$\begingroup\$ Please edit your question and add a link to the datasheet. \$\endgroup\$ – Bence Kaulics Dec 20 '16 at 13:04
The 8051 (original 'flavors') does not output a '1' with much drive capability. It is better to connect your LED + resistor from the output to Vdd and drive the pin low to turn the LED on. You could also add a pull-up to Vdd and shunt the LED, but that wastes power.
Edit: as per request, below is the i8051 I/O structure from the MCS-51 manual.
The strength of the pull-ups varies according to the type, but can be as high as 30mA nominal for the brief strong pull-up, and tens or hundreds of uA for the weak.
  • \$\begingroup\$ I know that microcontrollers "generally" can't drive LED's this way, i just want to know if the microcontroller pin acts as a FLOAT or HIGH if i used the instruction MOV P1.0, #1. \$\endgroup\$ – HumbleUser Dec 20 '16 at 12:15
  • \$\begingroup\$ It is weakly pulled to a high with a brief stronger pulse to high to drive external capacitance. So the answer is not so simple. \$\endgroup\$ – Spehro Pefhany Dec 20 '16 at 12:16
  • \$\begingroup\$ If it can't drive, then it can usually not sink current either. Just put a transistor/buffer in between the MCU and the LED(s). \$\endgroup\$ – Lundin Dec 20 '16 at 12:35
  • \$\begingroup\$ @Lundin In this case, the output is quite capable of sinking enough current to drive a modern LED. The p-channel drive is made deliberately weak. \$\endgroup\$ – Spehro Pefhany Mar 14 '17 at 12:50
It depends in the output pin driver.
  • If it is an Open-Drain type then the pin can either float or tied to ground.
  • If it is a Push-Pull then it is either tied to VCC or ground.
At many microcontrollers this can be configured so you should cehck the datasheet about the default setup.
  • \$\begingroup\$ Actually it is neither open drain nor push-pull. The 8051 uses pseudo-bidirectional outputs. \$\endgroup\$ – Spehro Pefhany Dec 20 '16 at 12:12
  • \$\begingroup\$ @SpehroPefhany That is an Open-Drain type with internal pull-ups? \$\endgroup\$ – Bence Kaulics Dec 20 '16 at 12:16
    \$\begingroup\$ It's even a bit more convoluted- there is a weak pull-up MOSFET and a stronger MOSFET in parallel that is pulsed on during low-to-high transistions to quickly charge capacitive loads. \$\endgroup\$ – Spehro Pefhany Dec 20 '16 at 12:19
    \$\begingroup\$ Someone else edited that into my answer and it is a simplified view. I've added a more complete schematic and a link to the original data to my answer here. \$\endgroup\$ – Spehro Pefhany Dec 20 '16 at 12:46
    \$\begingroup\$ @SpehroPefhany Thank you I appreciate you efforts. \$\endgroup\$ – Bence Kaulics Dec 20 '16 at 12:49
