I have bought a phono-preamp stage from Audio Technica, and the output is quite low. (Using a MM cartridge.) I managed to retrieve a data-sheet which shows how the circuit is laid out. I'm not entirely sure how to proceed. The setup seems to be a fairly standard non-inverting OP-Amp setup. The Equalization appears to happen in the feeback. I initially thought R28/R18 were responsible for the gain but that doesn't seem to be the case.
I'm a bit stumped and would love to know if anyone knows if what I'm attempting to do is even possible.
Thanks!
