So I'm doing some modelling in a power systems simulation software (PSCAD)
I'm using the integrator block in that software.
Now unlike SIMULINK PSCAD doesn't offer a \$ 1 \over s \$ block but offers a \$1 \over s*T\$ block where \$ T \$ is the time constant.
I just want a simple integration operation done, i.e:
When I input
$$ A*sin(100t) $$
I want to get
$$ -(A/100)*cos(100t) $$ What should I set the time constant \$ T \$ to get this basic result?
    \$\begingroup\$ You answered your own question- You want 1/s, so T=1. \$\endgroup\$ – John D Dec 21 '16 at 22:52
  • \$\begingroup\$ Thanks. I just realised that shortly after positng. I had a long day at work :) \$\endgroup\$ – CKCK Dec 21 '16 at 23:03
\$\frac{1}{sT}\$ is just the same as \$\frac{1}{s}\frac{1}{T}\$
So set T = 1 or use it to set the gain of your integrator
