The below image is the setup I would like to have in my car.
I tried to illustrate it as best as i can. I do not want to go straight to my car battery for warranty purposes.
So my questions are:
  1. What size fuses do I use and where do i put them? I am able to insert a fuse at the cigarette lighters.
  2. What size wires must i use?
  3. Is there a better way?
Please feel free to edit the image.
Thanks
I hope there is enough information
  • \$\begingroup\$ that looks like 130W which is quite a lot for a cigaretter lighter socket. \$\endgroup\$ – Jasen Dec 22 '16 at 12:19
  • \$\begingroup\$ @Jansen You can extract 10 A from many lighter sockets but not all. \$\endgroup\$ – winny Dec 22 '16 at 15:10
The quick answer is that you should be OK, except that, if your 27 watt LEDs are 12 volt, they won't work, since in series each will only receive 6 volts. In comments Jasen suggested that the current drain may be too high. This discussion suggests that cigarette lighters are fused anywhere between 5 and 20 amps, so you'll need to check your owner's manual to find out just what your fuse really is. Also, I suggest getting rid of plug 2.3. The last thing you want to do is have someone plug in a lighter while the LEDs are on, since this will probably blow the fuse, and they are a pain to replace. Make sure any wiring is rated at the fuse current - Google on "ampacity" and use the smaller ratings for a given wire size.
| improve this answer | |
