-2
We are using SIM900A IC in our project. I found out that SIM900A is region based. What I want to know, will my device will work in Angola Africa?.
If not then what will be a compatible IC(Pin o pin) which I can use.
closed as off-topic by Voltage Spike, Dave Tweed Dec 25 '16 at 19:00
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Please provide a link to the data sheet and tell us what this device is supposed to do. \$\endgroup\$ – RoyC Dec 23 '16 at 13:57
  • \$\begingroup\$ Google says: simcom.eu/… \$\endgroup\$ – Richard Crowley Dec 23 '16 at 14:12
The web page shows that the SIM900A is "dual-band GSM/GPRS 900/1800MHz". That means it will only operate if you have GSM cell service at 900 or 1800 MHz. This is not "regional", it is based on what technology (GSM or CDMA) and what frequency bands (the most popular are 850, 900, 1800, and 1900 MHz) are used by the carrier of your choice in your area.
There are cell modules that will operate both GSM and CDMA, and are "quad-band" (operate at all four of the most popular frequency bands) that are typically used to have the best chance of operating in most places on the planet. Perhaps you should investigate using a "universal" quad-band cell module.
This website lists that Angola does use 900 MHz and 1800 MHz, the band SIM900A uses, so it should work there.
http://www.worldtimezone.com/gsm.html
