i am doing a cycloconverter single phase design and i have a problem , i use microcontroller to control the firing angle ,i have used zero crossing voltage (741) to trigger INTERRUPT port of MCU , i have controled two positive waves well but two negative waves dont work in reality . my question is " i want to use directly MOC3021 to control the two negative waves with load resistor 100ohm ?" And i will use MOC3021 inside triac to control negative waves instead of 2 SCR negative direction but it doesnt work.Can the MOC3021 drive directly load 100ohm Vin=6VAC
[![enter image description here][2]][2]
Thanks guys!
