I need some way to be able to lie down in bed and watch stuff on my PC without disturbing people in other rooms. I have looked into wireless headphones, but am concerned about static issues, having to charge them, etc. I then began looking into 3.5mm audio cable extensions for my wired headphones. I am looking at a 12 foot extension cable on Amazon. The headphones I have now do just fine for gaming, TV, etc. and their cable is about 4 feet long.
Are there any electrical issues I should be concerned with? I vaguely recall something from a transmissions line web course that I took about the importance of impedance matching to minimize reflections (and thus sound distortion?)...
At audio frequencies, transmission line effects will not be noticed. Maybe if the cable was several km long then yes but, this would be a ridiculous length for a headphone cable.
It is the wavelength that is important and at 20,000 Hz the wavelength is 15 km. A general rule of thumb (in avoiding reflections) is that cables can be unmatched providing the length does not exceed one-tenth of a wave length - that's 1.5 km however, the signal amplitude would be so small at this length that it wouldn't make any difference.
Lower frequencies have a longer (less "problematic") wavelength.
  • \$\begingroup\$ Yes. But avoid cables that are way too thin, because voltage drop needs to be compensated by cranking up the amplifier, potentially increasing the distortion. \$\endgroup\$
    – Dampmaskin
    Commented Dec 26, 2016 at 15:47
    \$\begingroup\$ @Dampmaskin If the cable is that thinn, it would break due to any mechanical handling anyway. \$\endgroup\$
    – winny
    Commented Dec 26, 2016 at 16:52
