I am trying to determine the correct batteries required for my Arduino (Atmega 328) project. I have components which have both voltage and current ratings. I am adding up all the maximum current specifications from the components to determine the ideal mAH.
I am currently stuck on the Atmega328 chip. I read the datasheet, but I cant seem to find the specific current draw of the chip. My understanding is that the operating voltage is ~5V, and the current draw of the chip would be ~40mA. But if I am using 6 pins (3 analog, 3 digital), assuming they all output 40mA at the same time (which is unlikely as the 3 analog pins take in x,y,z values from an accelerometer), would it be safe to assume the current draw of the chip would be 240 mA? (this sounds wrong)
