As you see in the attached picture. Two component's top overlay is above in my pcb design; I saw a error, but Altium Rule check does not inform me. I need a rule for this error. Can you help me?
Need Rule
    \$\begingroup\$ Are you sure it's actually an overlay? The line thickness probably isn't part of the DRC computation. \$\endgroup\$ – W5VO Dec 29 '16 at 7:25
  • \$\begingroup\$ I am pretty sure layers rule is work clearly. This picture is a sample. I want to see components above error. But I do not know which rule. \$\endgroup\$ – O.Blue Dec 29 '16 at 7:28
You can't create a rule using the Top Overlay as an outline. If you want to have the clearance between two components checked, create 3D models and a component clearance rule.
  • \$\begingroup\$ Thank you very much. I have 3D Models. Now İt is work . so There is no problem with components' top overlays \$\endgroup\$ – O.Blue Dec 29 '16 at 7:42
