For ultrasound transducers for imaging, high voltage drive pulses need to be generated, typically using a 3-level or 5-level pulser structure which resembles the image below. For a 3-level structure, two are connected together at the output, and for 5-level, three are connected.
The problem with this design is that discrete P-Channel MOSFETs are harder to come by with sufficiently high Vds(max) which must be at least 250V for a ±100V supply (when the output is -100V, the Vds of the PMOS is 200V). While they can be found, they generally have much higher Rds(on) and are much slower.
For one of the projects we are looking at, ideally we need to be able to drive a transducer at high frequency - 30-40MHz range - using a relatively arbitrary waveform (5-level PWM). However in order to achieve this the pulser needs to be able to switch somewhere in the region of 200MHz which means a rise time of <5ns which is beyond the range of what any of the available PMOS devices can do.
In order to get to this sort of level, the only thing I can think of is to replace the PMOS device with an NMOS device. However herein lies the challenge. Most of the high-side NMOS drivers are typically designed for applications like BLDC drives and DC-DC converter where the frequencies are in the 100kHz range at most. Additionally they and are not usually designed to cope with the high side gate sitting at negative voltages which would be the case at times in this pulser.
In order to switch from, say 0 to 100V in 5ns, the source of the high-side NMOS has to slew at more than 20kV/us which means whatever is driving the gate must be able to cope with such a high common mode transient. It must also be able to drive the gate fast enough to switch in <5ns which is quite a current spike although that will depend on the gate capacitance of the MOSFET.
I've been looking at ways to translate the signals from the logic circuitry through to the gate of the NMOS but am struggling to find anything fast enough. Optoisolators max out in the 25MHz range, and the only digital isolator I have found is the ADN4650 which can doo 600Mbps but those are not cheap and would require additional LVDS-LVCMOS circuitry which will take up space, especially when the channel count goes up (e.g. 16 element). Passive level shifters would be even more tricky to implement as the source will be going negative as well as positive.
So on to the question. Basically has anyone developed such a high frequency high-side drive? or have any ideas on circuitry that could be used to drive it?
