Maybe this is a dumb question, but I am trying to get my units straight.
I have an electrical system which has its consumption metered every hour, so I need units that are graduated in hours.
So, given SI units, should I base it in "Joule hours" which would be Watts * 3600?
In other words, let's say I have a 100 Watt light bulb and it runs for 3 hours. Then energy consumption would be 100 * 3600 * 3 = 1,080,000 Joule-hours. Is that right?
  • \$\begingroup\$ uh, a Watt-hour is 3600 Joules \$\endgroup\$ – Jasen Dec 31 '16 at 10:11
No, there is no need to say anything other than joules.
Your lightbulb has consumed, over the 3 hour period, 1,080,000 joules of energy. It's as simple as that.
If you had a tap running to fill up a 1000 gallon container and it took one hour to fill the 1000 gallon container you wouldn't say you have used 1000 gallon-hours of water. That would be stupid.
Watts are units of power.
Watts multiplied by time gives energy.
Joules are energy units.
1 Joule is 1 Watt multiplied by one second.
If you multiply Watts by a time period in seconds, then you have the energy in Joules.
Your example is 100 Watts for three hours. That is 100 * 3600 * 3= 1080000 Joules.
It is also 300 Watt hours. That may be where the confusion is coming from.
You are skipping the conversion: 1 W = 1 J/s
\$Energy = P\ t = 100W \times 3 hr \times \frac {3600 s} {hr} = 1,080,000\ W\cdot s\$ \$Energy = 1,080,000\ W\cdot s = 1,080,000\ \frac{J}{s}\cdot s = 1.08\ MJ\$
