How does voltage bias affect a photovoltaic cell? I'm receiving conflicting opinions online, with some saying that photovoltaic mode is entered only with forward bias, some saying reverse bias, and some saying no bias. Furthermore, is there a breakdown voltage for photovoltaic cells? The Shockley equation as I understand it (\$I = I_0(e^{(eV/k_BT)} – 1) – I_p\$) physically cannot tend to negative infinity as it's an exponential equation.
Thanks!
    \$\begingroup\$ Interesting question. I don't know the answer. But it occurs to me that people might write better answers if you can add a little information about why you want to know. I mean, maybe you are just curious, or maybe you have some kind of specific application in mind. \$\endgroup\$ – mkeith Dec 30 '16 at 18:24
    \$\begingroup\$ I'm just trying to understand the theory with no applications in mind, if that helps. \$\endgroup\$ – ThirtyOneTwentySeven Dec 30 '16 at 20:03
If you're asking whether light is converted into photocurrent only under specific photodiode bias voltages, the answer is that photovoltaic action is (mostly) independent of the PD bias. Notice that the photocurrent, Ip, is independent of the diode voltage, V, in your equation.
In communications circuits, photodiodes are operated with negative bias or zero bias. PD's are not operated with forward bias, because it saturates the device(somewhat defeating the purpose of having a photodiode), as well as increasing junction capacitance (undesirable in high speed optical communications circuits). Some sources classify "photovoltaic" mode as the mode under negative bias, and "photoconductive" mode as the mode with zero bias.
Yes, PD's have a reverse breakdown voltage, as does every diode. In high speed PD's used in optical communications, this reverse breakdown can be quite low, about 4-5 V. For PD's used in power generation, the reverse breakdown voltages are much higher.
Typical PIN diode characteristics: enter image description here
Some photodiodes have much higher reverse voltage (up to 200 V) and are used very close to their avalanche point. This gives these diodes much higher effective optical gain (100-100*) than a low voltage PD.
| improve this answer | |
  • \$\begingroup\$ Thanks for your detailed response! So just to clarify, if I have an ordinary solar panel, that I'm just using to generate electricity, the bias I apply doesn't matter as long as it's not near the positive or negative breakdown voltages, right? \$\endgroup\$ – ThirtyOneTwentySeven Jan 2 '17 at 1:29
