I am trying to plot a transfer function, and plotting the magnitude appears to show that it is a band-pass filter, which seems reasonable.
The problem is, the phase plot does not match with the magnitude plot at all. The phase plot just looks like the magnitude plot inverted. How is this possible?
I've attached my Matlab code and a figure
(the top plot is magnitude and bottom plot is phase) Plot
Here is also my Matlab code and the function that I want to plot. My question is: what is wrong with my code, and how is this possible at all in general?
numElem = 2000;
w = linspace(1,2*pi*10^20,numElem);
wRes = 2*pi*10^9;
%%Insert wRes (resonant frequency)
for n = 1:numElem
    if w(n) > wRes
        w = [w(1:n - 1), wRes, w(n:numElem)];
        resLocation = n;
        break
    end
end
freq = w ./ (2*pi);
lambda = 299792458 ./ freq;
%Beta
B = pi/2 .* w ./wRes;
B(resLocation) = pi/2;
%Distance
d = lambda ./ 4;
Z0 = 50; %Ohms
C = 10^(-12);
L = 1/(wRes^2*C);
Zl = 1 ./ (j .* w .* C + 1 ./ (j .* w .* L));
y = 1./((Z0./Zl).^2 .* j.*sin(B .* d)/2 + exp(j .* B .* d).*(1 + Z0 ./ Zl))
Amplitude=20*log10(abs(y));
phase = angle(y)*180/pi;
subplot(211)
semilogx(w,Amplitude)
subplot(212)
semilogx(w,phase)
Using a linear spacing for the samples on a logarithmic plot gives a strange result because in the plot the points are not equally spaced any more. Modifying the code to show the calculated points reveals the problem: enter image description here
It's better to use a logarithmic spacing as shown below. I've also unwrapped the phase.
numElem = 2000;
%% --> w = linspace(1,2*pi*10^20,numElem);
w = logspace(0, log10(2*pi*10^20), numElem);
wRes = 2*pi*10^9;
for n = 1:numElem
    if w(n) > wRes
        resLocation = n;
        break
    end
end
freq = w ./ (2*pi);
%Beta
%Distance
d = lambda ./ 4;
Z0 = 50; %Ohms
C = 10^(-12);
L = 1/(wRes^2*C);
%% --> phase = angle(y)*180/pi;
phase = unwrap(angle(y))*180/pi;
subplot(211)
semilogx(w,Amplitude, ':*')
subplot(212)
semilogx(w,phase, ':*')
Which gives the following result: enter image description here
  • \$\begingroup\$ Seems odd that the HF phase asymptote is not an integer multiple of 90deg \$\endgroup\$
    – Chu
    Dec 31, 2016 at 11:04
