enter image description here I have built my first ever OP-AMP RC Multivibrator using the schematic above. It produces a square wave, but it is somewhat problematic. The square wave has a duty cycle of only ~25%, and has a non-zero base value. To inspect this, I put a probe up to the points on the schematic labelled PROBE + and PROBE -. This is what my scope read: enter image description here
What seems to be happening here is that the capacitor seems to be both charging and discharging through the resistor. This is problematic because the duty cycle also based on the capacitor discharging to a non-zero value.
Here's a picture of the output (yellow) compared to VCC (blue).
The second problem is that the capacitor is charging to only 350mV, which results in a 350mV peak. Is this supposed to be the case? how would I amplify this? My first Idea was to hook up the output to a second OP-AMPs inverted in, and the positive rail to the non-inverting in, which should produce the inversion of the wave. I would then hook that up to a NOT gate to get the original waveform. The result of hooking this up to the OP-OP AMP is Shown above. The yellow line is the output of the multivibrating OP-AMP, the blue line is the result of the secondary OP-AMP. As you can see, the secondary input messes with the first output signal. I'm not sure why.
Any help with this would be appreciated.
OP-AMP datasheet: http://www.ti.com/lit/ds/symlink/ne5532.pdf
  • \$\begingroup\$ Apart from the supply voltage problem, if you want a sine wave, use a sine wave oscillator not a multivibrator. Search for "phase shift oscillator" (+audio) or "Wien bridge oscillator" and you'll find plenty - the phase shift oscillator is simpler but the Wien bridge is easier to tune. \$\endgroup\$
    – user16324
    Dec 31, 2016 at 11:41
You need to read your data sheet more closely. Specifically, read section 10.
The NE5532x and SA5532x devices are specified for operation over the range of ±5 to ±15 V
but you are trying to run it from a single +5 supply. So the op amp is not remotely happy. Furthermore, if you look at section 7.5, Maximum peak-to-peak output swing, you'll see that for +/- 15 volts the op amp is only guaranteed to swing +/- 12 volts, or within 3 volts of the power supply voltages. Notice that, if this applies to lower voltages (although there is no way to tell, since there is no spec for this, which ought to be an enormous red flag) there would be no output swing at all for power supplies less than 6 volts total. And this is pretty consistent with the 350 mV that you're getting.
Worse, there is no obvious reason for your oscillator to work. Consider the situation when the output transitions from low to high. The high output level both charges the capacitor AND sets the trigger level, so in theory it will take infinite time for the capacitor to charge to the point where it will trigger an output change. Given that real op amps have input voltage offsets, it would be perfectly possible for the capacitor never to reach a trigger voltage.
Furthermore, even if the circuit did work, why in the world would you expect a sine wave output? What you have made is a very bad version of a classic relaxation oscillator, and a square wave output is exactly what you'd expect. The capacitor voltage should then be exponential waveforms as the square wave charges and discharges it, and that (within the limits of your setup) is exactly what you're seeing.
  • \$\begingroup\$ the circuit does work. those are real screenshots from my oscilloscope. I don't expect a sine wave output, I expect a sine wave across the capacitor. \$\endgroup\$
    – tuskiomi
    Dec 31, 2016 at 3:46
  • \$\begingroup\$ Again - why? The output is a square wave, so the capacitor will follow a standard charge/discharge curve, which is to say exponentials such as you see. And yes, I know your circuit works, sort of, it's just that there is no obvious reason (other than noise) to expect that it would. \$\endgroup\$ Dec 31, 2016 at 3:50
  • \$\begingroup\$ I was learning from here: electronics-tutorials.ws/opamp/op-amp-multivibrator.html I expected it to look more like an LC curve... \$\endgroup\$
    – tuskiomi
    Dec 31, 2016 at 3:52
    \$\begingroup\$ Look at the section titled Op Amp Multivibrator Voltages. That is what you should expect. After all, you don't have any inductors in your circuit, now do you? \$\endgroup\$ Dec 31, 2016 at 3:54
    \$\begingroup\$ Absolutely. Just run it from +/- 15 volts. But don't use your botched circuit. Use the circuit shown in the article you linked. \$\endgroup\$ Dec 31, 2016 at 4:48
ne5532 is a poor choice for comparator application like this because it has back-to-back diodes across the inputs.
Try your circuit with a comparator or less-fancy opamp.
