Consider the following program segment on a hypothetical processor . enter image description here
I have this question in my course CS201. Suppose this processor has 32 bits Load/Store operations, ALU operations is 16 bits and Branch instruction is 16 bits. Program has been loaded in the memory with a starting address of 3000 (which is in decimal) .
Assuming Byte addressing, If the interrupt occurred during the execution of halt instruction, then the return address pushed onto the stack will be ?
My Try :
I referred this link
http://x86.renejeschke.de/html/file_module_x86_id_134.html
According to this link, The return address saved on the stack must be of instruction after the HALT instruction, which gives me the saved address as
3000 + 4 + 2 + 2 + 2 + 4 + 2 + 2 = 3018
Hence, Stack saves 3018 .
But, I don't have the answer with me, so I can't confirm it.
Am I going Right ?
Of course. Otherwise the CPU would go into a HALT instruction again after returning from the interrupt.
Some information is missing: Either the information, that "HALT" is a "branch" instruction on the given CPU (on modern automotive CPUs "HALT" is a special instruction class, not "branch") or the information how long "HALT" is.
Assuming "HALT" is also 16 bits long: Yes, it's correct.
    \$\begingroup\$ If interrupts are disabled by software, nothing will happen within HALT instruction. \$\endgroup\$
    – Anonymous
    Dec 31 '16 at 8:29
  • \$\begingroup\$ Thanks for the answer !! Just one doubt "Interrupt comes during the halt instruction" and "Interrupt comes after halt instruction", both are same ? I think so, because interrupts are always processed after completion of instruction. Am I right here ? \$\endgroup\$
    – Garner
    Dec 31 '16 at 8:30
    \$\begingroup\$ Yes, @Garrick, you are right. An interrupt is processed only after current instrucion has completed \$\endgroup\$ Dec 31 '16 at 10:53
  • \$\begingroup\$ Depending on the implementation, HALT may not be so benign... en.wikipedia.org/wiki/Halt_and_Catch_Fire#Intel_x86 \$\endgroup\$ Dec 31 '16 at 19:18
