-1
This is my timer 4 init:
void initTimer(){
  CLK_PCKENR1 |= (1<<4); //Enable Clock for Timer 4
  TIM4_EGR |= 1;
  TIM4_PSCR = (0x03);    //Prescaler, Divide Clock by 7
  TIM4_IER = 1;          //Enable Update Interrupt
  TIM4_CR1 |= 1;         //Enable Timer
This is my service routine:
#pragma vector = TIM4_OVR_UIF_vector
__interrupt void TIM4_OVF(void){
  if(!didInit){
    initMAX7219();
    didInit = true;
  applyBuffer();
  shuffleRight();
  TIM4_SR &=~(1<<0);    //Clear Update interrupt flag
But nothing works, the timer counter register gets incremented properly but the interrupt function is never reached, why?
Happy new year!
    \$\begingroup\$ Because of TIM4_PSCR should be power of 2. Should be one of: 1,2,4,...,128 \$\endgroup\$
    – name
    Jan 17, 2017 at 14:16
    \$\begingroup\$ Did you enable global interrupts (i.e. EA=1) ? \$\endgroup\$ Jan 17, 2017 at 14:21
working code:
void TIM4_init(void){
TIM4_PSCR = 7;
TIM4_ARR = 250;
TIM4_IER |= TIM4_IER_UIE;
TIM4_CR1 |= TIM4_CR1_CEN;
void  TIM4_overflow_interupt()  __interrupt (TIM4_UPD_OVF){
static unsigned nu = 0;
static unsigned pi = 0;
if (nu >= 100){
    nu = 0;
    if (pi){
        pi = 0;
        IND_LED_ON();
    else{
        pi = 1;
        IND_LED_OFF();
nu++;
TIM4_SR1 &= ~TIM4_SR1_UIF;
//TIM4_IER |= TIM4_IER_UIE;
  • 4
    \$\begingroup\$ Please give some more information on your code example. Just posting a snippet is not an answer. \$\endgroup\$
    – Ariser
    Jan 18, 2017 at 10:40
