1) I need to reduce 120v AC supply to 100v for a japanese piece of equipment which has a AC transformer inside rated at 100v. There is only one primary (100v AC) and one secondary (30v AC) winding on the 100v transformer. Device pulls only 4 amps. The fix has to be internal since it gets moved around a lot. There isn't very much room inside either. 2) I hesitate to run 100v transformer on 120v AC for any long period. Am I being overly cautious?
    \$\begingroup\$ The overly cautious question is difficult to answer because we dont know what the 30V is driving. \$\endgroup\$
    – RoyC
    Commented Jan 1, 2017 at 21:57
There are two possible sources of difficulty.
First, running a transformer at 20% higher than design voltage nominal runs a serious risk of driving the core into saturation if the mains happens to run a bit higher than nominal. However, part of Japan is 50Hz and part is 60Hz, and I am going to guess that your 120VAC is 60Hz, so chances are it is not a problem if the transformer is marked 50/60Hz. A 50 Hz 100VAC transformer can be run at 120VAC 60Hz.
Secondly, the higher than normal output voltage could stress whatever it is connected to, such as capacitors. There could also be additional current that would cause the transformer to overheat. We have no way of guessing what might go on there, but chances are it is not good,
You can buck the voltage with an autotransformer configuration (VA will be 1/5 of using a 120:100 step-down transformer), replace the transformer, or in some cases (eg. toroidal transformer) you may be able to add a few extra turns to buck the secondary voltage (presupposing the primary is okay, as discussed in point 1 above). Typical volts per turn is around 1 so it might take 5-10 turns of suitably heavy and insulated wire.
Don't muck with this unless you are 110% sure you won't compromise the isolation between primary and secondary- that's a safety issue.
Frankly if this is piece of (say) music equipment that is being moved to different gigs and used by random people (for example) I would strongly suggest replacing the transformer with an approved unit and having the unit inspected for safety.
  • \$\begingroup\$ Thank you sincerely for taking the time. Being that safety is my first concern, it looks like I will be purchasing an (expensive) proprietary 120/30 transformer for this technics 1200 turntable. So far, cheaper transformers online mount wrong or are too bulky. The autotransformer option is interesting, I've never tried it and I'm willing to learn but seems like not this time. One other option I'm considering is to build an external power supply for it and lose the internal transformer entirely. Maybe. Thanks again. \$\endgroup\$
    – user134700
    Commented Jan 2, 2017 at 12:57
I see a couple of options:
  • Replace the existing transformer outright.
  • Install a small extra transformer wired as an autotransformer to reduce the voltage.
For the second option, note that the secondary of the extra transformer only needs to carry the primary current of the main transformer; i.e., 20 V @ 4 A. This 80 W transformer should be significantly smaller than the 400 W main transformer.
