-5
Where are the inputs and outputs in this schematic? Are there one or two?
closed as unclear what you're asking by Marcus Müller, Bimpelrekkie, Autistic, Dave Tweed Jan 2 '17 at 12:54
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ IT LITERALLY SAYS IT IN THE SCHEMATIC DIAGRAM... \$\endgroup\$ – Bradman175 Jan 2 '17 at 3:12
It's an oscillator: no input. Vout is the output.
  • \$\begingroup\$ What is the 9v for then? \$\endgroup\$ – Antonio1234 Jan 2 '17 at 2:35
    \$\begingroup\$ The 9V is the power supply - I don't usually think of the power supply as an input to an amplifier or oscillator. \$\endgroup\$ – Peter Bennett Jan 2 '17 at 2:40
  • \$\begingroup\$ @PeterBennett ok so the 9v power supply would be the positive terminal of a 9v battery for example \$\endgroup\$ – Antonio1234 Jan 2 '17 at 2:44
    \$\begingroup\$ Yes - and the negative terminal of the 9 volt battery would connect to "GND" in the drawing. \$\endgroup\$ – Peter Bennett Jan 2 '17 at 2:56
