I have a UHF TV antenna for ISDB-T Digital TV reception. The transmitter just one only antenna is 70km away and some channels suffer from some "digital noise". That's it, the image is not perfect and some frames are lost.
The transmission line to the antenna is a standard 75 ohm coaxial cable. However, the antenna has a 300 Ohm impedance and I'm using a 4:1 balun to match the impedances.
Does changing the line to 300 ohm ribbon and putting the 4:1 balun right next to the digital TV receiver will enhance the reception?
In the ARRL Handbook 2010 section 20.4.4 ("Matching the Line to the Transmitter") there is a table showing that the most loss is having the balun right next to the antenna (like my setup).
Why does placing the balun at the receiver and using a balanced line result in better performance that using an unbalanced feed line like coax and placing the balun at the antenna?
EDIT: I'm also looking for some theory and some comments on a balun. Is there any 4:1 balun I can build that has a wide bandwidth on the 473-800 Mhz range?
    \$\begingroup\$ Weren't one-off hacks allowed on this site? This looks like that to me... \$\endgroup\$
    – AndrejaKo
    Mar 9, 2012 at 21:55
    \$\begingroup\$ This just looks like someone trying to hook up an antenna to their TV, but maybe I am wrong. \$\endgroup\$
    – Kellenjb
    Mar 9, 2012 at 22:24
    \$\begingroup\$ When did discussing the losses of various transmission lines become outside of the discipline of EE? \$\endgroup\$
    – JonnyBoats
    Mar 10, 2012 at 1:46
    \$\begingroup\$ @JonnyBoats I didn't see any attempts from the OP to care to understand transmission line theory. I took it at just wanting to know what was the best way to hook it up. Your answer also supports that this really doesn't have anything to do with electronics design, rather only how to hook up some consumer electronics. Go into some actual EM theory and it will very much be on-topic. \$\endgroup\$
    – Kellenjb
    Mar 10, 2012 at 2:58
    \$\begingroup\$ Sometimes you don't know what you're asking. I think we can answer the asker's questions with some good theory. The asker is happy, and we're happy because knowledge is shared. Win-win! \$\endgroup\$
    – akohlsmith
    Mar 11, 2012 at 17:35
All transmission lines suffer some loss, you will never get as much power out at the far end as what is put in at the source. This is true for both transmitters as well as receivers. For direct current (DC) the loss will be the resistive loss of the wire or other conductors used. At higher frequencies the resistive losses still occur, but other losses occur as well due to the dielectric loss which increases as the frequency increases and is generally much higher than the resistive loss.
In coax the dielectric is generally some sort of plastic located between the center conductor and the outside braid.
cutaway view of coax cable
Balanced line may come in the form of twinlead,
twinlead
ladder line
or open wire line
open wire transmission line
With a balanced line the only reason to have anything at all between the two conductors is to maintain a uniform spacing and for this reason the less material the better. This is also true of coax, but much harder to implement in practice. Further there is generally a greater distance between conductors in all types of balanced lines than with coax.
Generally air makes a much better dielectric than any other substance when size is not an issue since free air does not degrade over time. It is the nature of the dielectric which primarily determines the signal losses at radio frequencies and as the ARRL handbook pointed out, losses for coax are higher than for balanced lines and the higher the frequency, the greater the advantage.
As a side note, the preceding assumes a perfectly matched line, in other words the source impedance = the load impedance = the characteristic impedance of the line. When there is any sort of a mismatch, a standing wave ratio (SWR) will be greater than unity and losses in coax will increase dramatically with an increase in SWR.
You are quite correct that the loss per foot for open wire line at these frequencies is far less than coax; if it is properly installed. This is a big if. The first thing I would check is the type of coax you are using. Is it some cheap, generic stuff from a place like Radio Shack or is it a premium quality product from a firm like Belden designed specifically for low loss at UHF frequencies? Your ARRL handbook lists loss for different types of coax.
Another thing to try is a mast mounted preamp at the antenna. It is better to boost the signal before the transmission line rather than after.
Getting back to how to best install open wire line, it should run straight in free air from the antenna to where it enters the building. Taping it to a metal mast, bending around corners, running it through walls etc. will all cause it to perform in a far from ideal manner. Coax suffers far less from such treatment.
I think the ARRL guideline is not so much to have the balun at the "far end" but rather to minimize losses at the frequency you're working at. Take a look at the cable loss per foot for 300 ohm twinlead vs quad-shield 75 ohm coax at the frequency your weak station is at. You might be surprised.
In the end, you want the balun placed where it makes sense. If your antenna impedance is 300 ohms and the cable from the antenna to the ground is 75 ohms, then you must put your balun at the antenna, because it needs to match the impedance of the antenna to that of the transmission line. If you were using standard 300 ohm twinlead, then you would place your balun at the TV, where it is expecting 75 ohms and the 300 ohm twinlead is the mismatch. Either way, you want to make sure your low noise amplifier is as electrically close to the antenna as possible; Most amplifiers are 75 ohm, so you'll have to have a balun between the antenna and amplifier, so use excellent quality cable and rigid, weatherproof mounting techniques. You're trying to pick up super weak stations and every connector, device and kink in the cable ends up weakening the already weak signal you want. The quality and length of the cable AFTER the LNA is less important than the connections from the antenna to the LNA, but you really do want to take your time and spend the money on top-notch kit for those first 6-12 inches.
Don't be afraid to try other baluns; I have seen a huge difference in quality between different baluns, and cost is NOT an indicator of performance. The standard "PCB trace shorted stub" baluns that are part of most antennas you can buy today are total garbage. The old torroidal baluns found on the back of 25 year old televisions are better! I've generally found that the baluns that actually use transformers in them are the best, but that is a pretty broad statement to make without qualifying it, so do your own experimentation. :-) The good news is that baluns are cheap. Try a few different ones. Climbing the tower is a pain, but without devising an entire test system and trying them on the ground that's probably the quickest way to solve your problem.
Building coax loop baluns is pretty easy. Before the digital switchover in Canada I was pulling in all of the stations from Toronto's CN Tower with a homemade balun and a good quality LNA. I'm about 80 miles away (as the crow flies). With the balun provided with the antenna I could only pick up CBC. With a cheap $2 Home Depot balun I could get pretty much everything, and with my own balun I got everything in solidly. I tuned my coax loop balun to have the best impedance match at the frequency of the weakest station. The 4:1 voltage loop coax loop balun I built can be seen here: http://www.digitalhome.ca/forum/showpost.php?p=992185&postcount=502. The entire thread is an excellent read, as are most of the threads in the antenna design part of that site.
  • \$\begingroup\$ Some of the coax baluns I've dug on the internet are for a very narrow bandwidth on a specific frequency. Does that coax balun you linked work on the entire UHF band? \$\endgroup\$
    – user2798
    Mar 13, 2012 at 2:32
  • \$\begingroup\$ Yup, a 1/2 wavelength coax balun (your link) works best on a narrow bandwidth. vk5ajl.com/projects/baluns.php#voltage \$\endgroup\$
    – user2798
    Mar 13, 2012 at 2:48
  • \$\begingroup\$ I can't find the theory page I used when building that particular balun, but I seem to remember the bandwidth being wide enough that I was really not worried about loss at either end of the ATSC spectrum. I did tune it so it'd have as low loss as possible at the weakest station's frequency, but other than that, I have no numbers to provide. I'll keep looking and if I can find it I'll update the answer. \$\endgroup\$
    – akohlsmith
    Mar 13, 2012 at 3:21
