I am running below code in a PIC16F887 that runs at 20 MHz. I feed PORTB.0 a signal of 1 KHz from my signal generator. However, whenever the signal is low, PORTC.1 toggles at a rate of either ~5usec or ~10usec. Also, I've connected an OP-AMP's output that gives 0V-4V, still the same.
I have tried enabling weak pull ups inside, didn't work.
The microcontroller is on an EasyPIC5 development board, so I can enable and disable either pull-up or pull-down resistors that are 10K. Didn't work, either.
Is this some kind of silicon problem(?) or is there a mistake in my code?
Here is a screenshot from the oscilloscope that probes PORTC.1:
Here is my code, please omit off-topic part of it:
volatile unsigned int fiftymicros=0;
volatile unsigned int milis=0;
volatile unsigned char fiftymicroscounter=0;
volatile unsigned int data_time=0;
volatile unsigned int milis_ctr=0;
unsigned long int data_bar[20]={0};
void interrupt()
     if(INTCON.T0IF)
      TMR0=198;
      INTCON.T0IF=0;
      fiftymicros++;
      if(++fiftymicroscounter==40) { fiftymicroscounter=0; milis++; }
     if(INTCON.RBIF)
      PORTC.F1=~PORTC.F1;
      INTCON.RBIF=0;
void main()
     ANSEL =0;
     ANSELH=0;
     TRISA=0; PORTA=0;
     TRISB=0x01; PORTB=0;
     TRISC=0; PORTC=0;
     TRISD=0; PORTD=0;
     TRISE=0; PORTE=0;
     OPTION_REG.INTEDG=1;
     OPTION_REG.T0CS=0;
     OPTION_REG.PSA=0;
     OPTION_REG.PS0=1;
     OPTION_REG.PS1=0;
     OPTION_REG.PS2=0;
     //OPTION_REG.B7=0;
     //WPUB=0x80;
     INTCON.TMR0IE=0;
     INTCON.RBIE=1;
     IOCB.B0=1;
     INTCON.GIE=1;
     UART1_Init(9600);
     Delay_ms(100);
     milis_ctr=milis;
     while(1)
    \$\begingroup\$ You are probably not clearing the condition properly on the high to low transition, so it keep recurring. \$\endgroup\$ Mar 10, 2012 at 0:01
  • \$\begingroup\$ @OlinLathrop I guess me blaming hardware prevented you from writing an answer :) ...silicon problem... \$\endgroup\$ Mar 11, 2012 at 11:46
You need to read PORTB before clearing the RBIF flag inside interrupt(), otherwise the mismatch will still exist and the RBIF flag won't be cleared. See section 3.4.3 INTERRUPT-ON-CHANGE in the PIC's datasheet:
For enabled interrupt-on-change pins, the present value is compared with the old value latched on the last read of PORTB to determine which bits have changed or mismatched the old value.
    \$\begingroup\$ I wonder why those application notes do not include C code. I am not against assembly, however, they should include both. AN566 supports this answer. EXAMPLE 1: SINGLE INTERRUPT WITH A SMALL PULSE ... CLR_RBINTF MOVF PORTB, 1 ; Read PortB (to itself) to end ; mismatch condition \$\endgroup\$ Mar 11, 2012 at 12:20
