I have a 5 Vpp max audio signal in my circuit which I obtain from earlier stages of processing. I would like to deliver the signal to a 20W 4 ohms speaker. But since an OPAMP circuit generates the signal, it won't be able to supply enough current. How can I use transistors to amplify the current delivered? I don't think I need a common emitter voltage amplifier since the voltage is already large. What amplifier topology should I use? What kind of transistors do I need for the purpose?
I'm trying to refrain from using specific ICs and use transistors instead, and I don't need a very complicated adjustable amplifier, my only goal is be able to listen to the contents of the signal. The 20 W speaker is necessary for my application, a weaker speaker will not do. I already have a 12 V and 30 V power supply used in the previous stages.
  • \$\begingroup\$ If you don't need anything fancy, use a dedicated IC. \$\endgroup\$ Jan 3, 2017 at 10:15
  • \$\begingroup\$ Have you tried listening to the speaker you have? Why do you think you need 20W to hear some random 'signal'? \$\endgroup\$
    – R Drast
    Jan 3, 2017 at 10:35
    \$\begingroup\$ Do you already have a power supply to run the amp? If your voltage is big enough, you can use a capacitive coupled emitter follower or you could go class AB. But this depends what you plan to use to power the amplifier. \$\endgroup\$
    – owg60
    Jan 3, 2017 at 11:17
    \$\begingroup\$ I'm trying to refrain from using specific ICs and use transistors instead Why ? You seem to assume that using an IC will be complex and using transistors will be easier. Actually the reverse is true. The easiest solution is to buy a simple ready made amplifier module. You can find these on ebay. All of these use an IC, I have not seen any using discrete transistors only. \$\endgroup\$ Jan 3, 2017 at 11:33
  • \$\begingroup\$ I'm not assuming that an IC solution would be more difficult, I prefer a transistor circuit for learning purposes. It is of course much easier to wire a ready made module to my circuit reading its data sheet. \$\endgroup\$
    – ntrstd11
    Jan 3, 2017 at 12:10
20 watts into 4 ohms implies an RMS sine wave voltage of \$\sqrt{80}\$ volts = 8.94 V RMS. The sine wave will peak at 12.65 volts and have a peak-to-peak value of 25.3 Vp-p.
For fairly straightforward amplifiers, this means having a total power supply voltage that exceeds 25.3 volts so maybe a +/- 15 volt power rail is worth considering. This leaves a little bit of headroom because most op-amps on +/-15 volt rails will probably only be able to swing to +/- 13 volts (26 Vp-p) and, with a push-pull emitter follower stage you should be able to achieve about 1 volt lower (under load) with a little bit of care.
So, a +/- 15 V supply will just about suit reproducing a sine wave of 20 watts power into a 4 ohm speaker.
However, if you are talking about music reproduction then it's a different story. Music tends to have a "crest factor" that makes delivering 20 watts a bigger problem. Compare a sine wave and music: -
For the same peak power delivered (2 watts) a sine wave would be delivering 1 watt (average) whilst music would deliver significantly less at below 0.1 watts.
So, you have to decide what you are talking about when you say 20 watts.
Anyway, the circuit is the same but the power rails are different so, toplogically, if you don't want to use a ready-made chip solution then consider adding an NPN and PNP transistor to an op-amp like this: -
The diagram above was taken from the DS of the OPA454.
It shows power supplies of +/- 50 volts but these could be more like +/- 16 volts for just delivering a sine wave of 20 watts to 4 ohms. I don't think it's useful to go into further details until you decide what you want (20 watt sine or 20 watt music).
  • \$\begingroup\$ What I meant was 20 W average for a pure sinusoidal, apologies for not clarifying. \$\endgroup\$
    – ntrstd11
    Jan 3, 2017 at 12:06
  • \$\begingroup\$ That's OK, I still added you a useful circuit to use that can run from supplies as low as+/- 5 volts. However, if you are prepared to go to maybe 15 watts output power the 12 V and 30 V power supplies you have could be made to work providing they can supply the current. \$\endgroup\$
    Jan 3, 2017 at 12:30
