Consider these two simple LC oscillators with ideal op-amps:
The resonance frequency is for both circuits about 159 kHz, however neither of the two will oscillate at that frequency in both the simulations and the real application. Why is that?
For instance, the first circuit, when tested, oscillates with a frequency of about 132 kHz and 156 kHz in the LTspice simulation. Ok, components are not perfect, but here we are significantly off the expected value. Furthermore, taking into account the internal resistance of the capacitor and inductor, if you consider a dumped RLC circuit with dumped oscillations, the frequency should still be the resonance frequency.
In many other (more complex circuits) I often read that the LC couple will oscillate at the resonance frequency $$\frac{1}{2\pi\sqrt{LC}}$$. However, this is almost never the case, and the frequency is far off that value (again, why?).
According to the oscillation condition (Barkhausen) a circuit with frequency-dependent feedback can oscillate only at a frequency where the loop gain is unity (or slightly larger). In particular, this means that the PHASE of the loop gain function must be ZERO.
For large frequencies (and the example frequency above 100 kHz can be considered as large) the phase shift of the used opamps must not be neglected. As a result, the frequency of oscillation (if the circuit does oscillate!) is the frequency where the passive network has a positive phase shift which exactly can cancel the (unwanted, but unavoidable) negative phase shift of the opamp. For this reason, the resulting frequency is less than the desired frequency.
(The passive LC circuit has a positive phase shift for frequencies BELOW the passive resonance point).
First Remark: The loop gain of a circuit with feedback is simply the product of the feedback network and the gain of the amplifier stage.
Second remark: The first circuit is not very common because it has no stabilizing negative DC feedback. The opamp is driven deep into saturation. Both resistors in the positive feedback path of the second circuit are too large (to much damping, bad selectivity). Good results for R2=R3=10 Ohms.
  • \$\begingroup\$ thanks that was helpful. From the answer I take that in general the frequency of oscillation is determined by the circuit as a whole and not just by the LC couple. Is that right? \$\endgroup\$
    – mickkk
    Jan 3, 2017 at 18:08
  • \$\begingroup\$ @mickkk, yes, this is exactly right - the frequency of oscillation is determined by the circuit as a whole. \$\endgroup\$ Jan 3, 2017 at 18:17
  • \$\begingroup\$ Yes - correct. It is the LOOP GAIN that matters only: Magnitude slightly > 0 dB and phase exactly zero deg. If the active element introduces some phase shift this must be taken into account. \$\endgroup\$
    – LvW
    Jan 3, 2017 at 18:18
  • \$\begingroup\$ A related question can be asked, why the signal amplitude does not go rail-to-rail, and settles to some nice sine wave. It would be nice to add small-signal vs large signal properties of OPA here. \$\endgroup\$ Jan 3, 2017 at 18:31
  • \$\begingroup\$ Which of the amplifier gains takes part into the loop gain:power gain,voltage gain or current gain? \$\endgroup\$ Jan 3, 2017 at 19:18
