I wanted to avoid using a soldered usb plug, and add copper pads directly onto my board to act as a usb plug.
Now I wanted to know how thick the board should be, in order to have a snug fit in any USB port.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI wanted to avoid using a soldered usb plug, and add copper pads directly onto my board to act as a usb plug.
I have a commercial version of what you are trying to build:
I measured the thickness at the end where the pads are with a pair of digital calipers, and it is 2.20 mm. The blue and black sections of plastic are flush with each other, there is no lip although there appears to be one in the photo.
