I am asking this question as I'm not too sure how to find a solution (nor how to search).
I am a real beginner in electronics and i need to make a simple circuit using a relay and 2 switches
so the basic functionality should be:
1)When I press button #1, the current goes to the motor, at the end of motor revolution, a mechanical arm pushes button #2 (the current does not stop until a full revolution is made (even if the button #1 is released).
2)When the button #2 is pressed by the arm, the button #1 should cutoff power (even if it's pressed - basically the motor should stop).
I am using a 11.2v li-po battery having 25-50C discharge rate.
What kind of relay do I need and how do I wire it?
Any help or links to answers are appreciated.
