I have a old dead lead acid battery with two cell and i refine it by adding distilled water. Before adding water battery's nominal voltage is 2.30V and when i connect it to 5V charger which have rating of 5V/1A battery shows charging voltage and current of 4.15V/135mA.Is this charger is too slow or its ok that voltage drops while charging?i think battery might chage beacause current flows !!!
1\$\begingroup\$ It is OK to charge a lead acid battery with low current. I can't tell from the information in this question whether the battery is good or bad. I think you should let it charge for a while and then see if it works well for you after that. In future, if you ask about a battery, please provide full information such as capacity or manufacturer and part number. \$\endgroup\$– user57037Jan 7, 2017 at 19:13
\$\begingroup\$ ITS HBL power system's battery 12AH at c100 & 9AH at c10 rate with 2 cell. \$\endgroup\$– RidhamJan 7, 2017 at 19:21
1 Answer
A low current trickle charge is better than no charge at all.
If you can keep the cells topped up with distilled water you should not cause any real damage even with a charge that is somewhat larger than optimal.
However at 2.5V per cell you are on the low side for real charging (spiral wound 'Cyclon' cells excluded where it is more acceptable) and should try to get a bit more voltage at about 2.8V per cell or 5.6V for your two cell battery.
Most of the current in the charging direction will be used for charging, less any internal discharge current due to age, electrolyte contamination or other damage. It will charge very slowly (88 hours with constant current and 100% efficiency However the current should fall close to zero when the cell voltage has reached 2.5V) and never reach a full charge though.
Your charger may be able to supply slightly more voltage to reach a full charge very slowly if it does not have tight regulation but this is not a sure thing.
